carburetor heat insulators
Can anyone tell me exactly what this material is? I'd like to get some bar stock of it and just make my own insulators from now on. Thanks
Teflon or also called PTFE is a material that can withstand high temperatures and is also a good temperature isolator.
It is only bad to glue
Whatever material the original parts are made of, is nice and stiff even at such a thin wall thickness.
Any idea what it is?
From the looks it could be PEI, Polyetherimid, or PSU (Polysulfon), both are a bit translucent. It's probably hard to get those. PEEK might be a bit easier to get. At least in Germany it is, don't know how the situation is in the US.
Andreas
Andreas
Probably you have the white stuff? That is the softest of them all. The black one is harder.
I only have white, but come to think of it I also have acetal which might work.
Keep us posted about your findings, I just bought a new insulator, but I'm interested in this topic, too.
Andreas
Andreas
Replacement OS insulators are cheap, and they shouldn’t need replacing except when they’ve gotten old and/or were messed with a lot from frequent carb changes or adjustments. DIY is always fun tho.
Also I tried ordering the insulator for my 11K carb three times from 3 different vendors. Each of them said "in stock" but eventually refunded the order after a few weeks, and blamed Horizon for poor inventory management... I don't know. I ended up waiting 3 months then ordering again, and that time one showed up.
Then I got the idea to make my own.
I did receive the plastics by the way. Theyre very similar materials, and likely either would work fine. Would be trivial to whip up some insulators in the lathe when I need to. Judging just by color alone, it appears the stock part is made from polysulfone.
Nice! I had the same experience here in Europe (Germany), these insulators are often sold out, but eventually I found one lately.
For the installation, OS states to use epoxy to glue it to the carb. I am lucky to have some special epoxy at home which is used for gluing strain gauges, which are made from Polyimid (Kapton). It is very thin, like CA, but seems to do the job quite well.
Andi
Andi
Andi
Andi
I paid about 20 bucks (USD) for that one insulator in the picture. I could make my own for about a dollar each now, so that's neat. I'll probably never ever need that many though!
