Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
How should engine bearings feel? >
Like Tree19Likes
Old 08-09-2022, 12:07 PM
  #16
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
As wingracer stated. You have to care for motor, no matter what. The fuel is Hygroscopic so it will attract water / rust.
Also many of us actually fully disassemble our top of the line motors to inspect and further clean them before break in. This way we know the true condition of the motor prior to use, and should anything happen.
Horatio and sn47som1 like this.
1/8 IC Fan is offline
Old 08-09-2022, 12:26 PM
  #17
Max Rackstraw's Avatar
Originally Posted by wingracer View Post
Your bearing feels gritty because it's rusted. Whatever you are doing in terms of fuel, after run and storage needs to change.
Im going to change fuel. Other than that my storage and after run is satisfactory in my opinion.
Max Rackstraw is offline
Old 08-09-2022, 12:34 PM
  #18
Originally Posted by 1995 Monster T View Post
I have never seen a new engine in 30+ yrs.
You know you can officially end the thread when Mr. Experience whips out this doozy😂😂
mrreet2001 likes this.
Werty Yui is offline
Old 08-09-2022, 12:49 PM
  #19
Ive noticed that it is good practice to disassemble and inspect new motors before break in... At the time when i first acquired this engine i was not as confident in my ability to assemble and disassemble these engines and thus i ran the engine and broke it in without ever looking at its internals (aside from having the head off) until now.
Now i am far more confident in my abilities and have cleaned this engine out and removed the rust from the crank. Its actually a very rewarding and satisfying process!
In future I will dissasemble and inspect my motors before running them. I will also be extra careful taking my time in the after run process.
Old 08-09-2022, 12:59 PM
  #20
I think i can draw a conclusion to this thread now for any future viewers to see.
I purchased this engine with a leaky front bearing from the factory and did not bother to look any further into it.
I proceeded to break in the engine with the leaky front bearing and this caused a less than ideal fuel mixture for break in (too lean).
At this point aside from the leak from the front bearing, nothing appeared to be wrong. The engine ran fine without any bearing noise.
After about 10 practice sessions at the track, i noticed the engine would not hold a tune or idle correctly. I would tune the high idle out, go out for one lap and then it would be all over the place again. The engine also made a strange metallic bearing noise at this point and the front bearing was leaking more than previously.
Upon inspection, the front bearing seal was leaking air and oil so needed to be replaced. The rear bearing was not smooth and felt slightly grindy as well as having some rust on the outer race.
The crankshaft was also rusty.
This means the rust on the crank and rear bearing outer race most likely caused the rear bearing damage in conjunction with a slightly lean fuel mixture caused by the front bearing seal failure, causing the rear bearing to emit a metallic bearing sound during running.
The lean fuel mixture during break in has probably also reduced the engine's overall lifespan.
The solution is new front and rear bearings combind with a strict after run maintenance regime, buring off all fuel in the engine for storage and removing all fuel from the tank and lines. After run oil should also be applied throughout the engine. It is also a good idea to inspect the internals of new engines before running them.
Thanks for the replies everyone
Old 08-09-2022, 02:49 PM
  #21
Nitro5270's Avatar
Default The ugly truth
Its alcohol based fuel!!
The only thing in the whole universe that can save your engine from rusting is you.
To trust in some drops of ARO or the nasty promises of the fuel manufacturer is just playing russian roulette.
stanleyw808 likes this.
Nitro5270 is offline
Old 08-09-2022, 09:01 PM
  #22
stanleyw808's Avatar
Hello Max Rackstraw,
If You have the time, You should take out the engine of the chassis. Take out the Air Filter and Manifold/Pipe, and close all the holes including the Fuel Nipple. Clean the exterior of the engine thoroughly. Then take out the Back Plate and put tissue/napkin on the lower side of the crankcase while tilting back the engine to absorb any fuel left on the crankcase. Then put some drops of After Run Oil and put back the Back Plate. You could store it inside a Zip Lock bag to further protect it.
A while ago I like to use TAMIYA Engine Treatment spray, it is the best product to avoid rust!!! But sadly it is not available anymore. I've been trying to spray WD-40 seems to be OK so far.
Cheers..
stanleyw808 is offline
Old 08-10-2022, 12:54 AM
  #23
The reason for changing fuel is more because the fuel i have now is quite old and used to sit in a non water tight garage.
Nitro5270 likes this.
Old 08-10-2022, 12:55 AM
  #24
Cheers..
Thats how i store engines when i know they are to be stored long term (minus the napkin, which is a good idea that I'll probably try), its certainly very good practice.
Old 08-10-2022, 12:58 AM
  #25
We've answered the question of are my bearings bad (probably)... And why they went bad... But does anybody have an answer to the title of this thread? Its not as important now since i dont need to feel the bearings or even look at them... I know they're bad. But for future reference, can anybody describe how engine bearings should and shouldn't feel?
Old 08-10-2022, 06:51 AM
  #26
mrreet2001's Avatar
All bearing should be smooth. and never gritty. The only thing that will vary is how free they are.
mrreet2001 is offline
