2019 Protek Samurai SO3 & R03 Engines
#31
i use my Blok AP 21J of my S03, Its scream like hell and run and idle insanely good!!
#32
Can anyone list the differences between the 21j, 22e and 22d carbs? What gives the 22e more power? And is the the same as the blok p and m carbs?
#33
Bumping this to the top, b/c lots of local SoCal racers are using a 21J carb on the 2103 R and S to make tuning more consistent.
After using the 22e and 22d carbs, I'm not a fan personally. Neither is Drake; there's a reason he outfits his engine & Ronda's engine with 21J carbs.
If anyone is having issues w/idle and wandering tunes, if you have a 21J carb to try, throw it on. The engines run better w/them IMO.
#35
Location: SO. CAL. Thunder alley, revelation raceway The Dirt -Perris RIP OCRC
I have the Samurai LRT carb on my Ninja Jx, can some tell me how there mid range needle looks, is it flush or in a bit? A caliper measurement work be appreciated if anyone has time? Thanks
#36
this carb is a Os 22c carb. This carb came on os b2102. the ninja B04 engine also used the 22c carb to. Usually 22c mid needle tends to be sunk in a bit. I don’t have a engine with me right when I’m posting this but I’ll post up when I do.
#37
Hello jersey & wfo,
If the Carburettor is the same as OS 22C Carb, the Mid Needle should be 1 turn-in from Flush. The Low Needle should be 1 turn-out from Flush.
Chees..
Chees..
samurai Lrt carb is carb that came on samurai 321b V2.
#38
I just ordered an SO3 broken by Adam Drake. I usually send to AMR but buying this already done is super convenient. I plan on installing it in my yet to be built XB8 2021, so hopefully I won’t have to take material off for ultimate fit. Question.. how important is it to get the matching pipe? I really like the looks and price of this Performa pipe but am assuming is not tuned for the Protek. Can this ruin an engine? https://www.absolutehobbyz.com/perfo...old-35-55.html
#39
I have an S03 Samurai that I've been running in my NB48 2.0 with Novarossi 9901 pipe and 41020 (ie, long) manifold. I basically only have 1 track to run, and it's very low speed so I figure bottom end power & acceleration take priority, even going so far as to run a 12T clutch bell.
I've wondered how much performance I'm leaving on the table, if any, by not running whichever OS/ProTek exhaust setup that is intended for bottom end. I'd hesitate to drop ~$70 to find out because I have a hunch that it would be hard to perceive any difference, but at $170? Pretty tough sell.
#40
Curious to know this as well, or something similar to this.
#41
#42
Hipex 2135 is a good pipe option for os based engines. Tebo runs one on maxima. Flashpoint 2146 that comes with fp02 (os spec 2) I believe is same pipe as hipex 2135. Maifiled used the flashpoint pipe on his cars at dnc 2 years ago.
ultimate 2141 works good on os also. Don’t get fast lock one though cause they have air leak.
I’ve seen my friend use a ultimate 2142 which looks like the orion performa 2149 on samurai s03 he likes it. I’ve seen a friend use a werks 2058 on os spec 2 2103R in truggy he liked it.
different pipes can work on different engines. If your after similar performance as the os 2090 get the hipex 2135 or flashpoint 2146. Stronger metal then os pipe to. I use 2135 on all my cars now.
#43
this is a brand new b2102 engine with 22c carb on it. measured with digital caliper.
Mid speed 0.62 IN
high 0.60 IN
low 0.36 OUT
#44
Haven’t seen any posts about the Ryan maifield edition Samurai. Ordered mine yesterday, will be here tomorrow. Any reviews/recommendations to change before first start?
#45
