2011 Dave Mapston Memorial
#31
This is my first time racing 8th scale truggy what kind of spare parts should i have on hand.
i got some of tjhe main parts i think would break or go bad or wear out.
i have
-steering blocks
- caster blocks
- rear axle carriers
- clutch shoes
-clutch shims
-upper shock bushings
- extra shock seals
- arms
-outer hing pins
- the aluminum wheel hex extender things
- axle pins
- wheel nuts
i know i am not going to be able to get parts at the track. so im planning ahead. i also know that truggy are built very well after seeing others go through larger crashes at other races.
and this is all for a rc8t championship edition.
thanks chris
i have
-steering blocks
- caster blocks
- clutch shoes
-clutch shims
- extra shock seals
- arms
-outer hing pins
- axle pins
- wheel nuts
thanks chris
#33
Is there any rules being in place for short course tires? Regarding caliber 2.0? Can we use them?
#37
whos in charge of the track layout this year?
#39
High speed Daytona corner and big air.Lee
#40
Fast , lots o jumps (launchers, joey style),baby bristol burm, step up, step down , no off camber angled jumps 300' away though please straight aways belong far away or down the middle of the track at an angle , just my opinion
and maybe try to place the technical areas underwear the lights are placed
#41
ya what he said. good luck. hope you have a lot of help! see you thurs night.
#42
#45
For those signed up in stock SC, bring mod gear just in case.
