Engine tuning
Hi all, Just wondering about tuning and if i am doing it correctly. I have a .21 novarossi 9 port with ceramic bearings in my mrx5 WC spec and i have idled it through around 6 tanks and drove it at the local car park. All is brand new. I am very pedantic about having it sounding right and making sure there are no lean fuel mixture sounds. When i punch the throttle, it operates perfectly and very punchy. However when i am at a speed and not wanting to slow down or speed up, i notice it sounds like it is leaning out and doesn't sound healthy at all.... Any suggestions as to what i can do to fix this??
I have tried making it richer on the high speed but it doesn't really help that and the idle screw a fraction. This worries me. I am wondering if because it is built for racing and i use it as a hobby that it either wants to go or stop instead of in between. Any advice for tuning would be great and would be appreciated.
Cheers for replying.. What exactly is a part throttle ? It also doesn't like to idle for anymore than 10 sec and when idling for a bit and then punch the throttle it bogs down.. So lean it off and for some reason it gets to the point where it is leaned off to much and still happens. I think i may have to adjust the idle gap. When i i gas it and it stops it keeps a bit of rev and then drops down to low idle
That does make sense. It is all factory set still except for the high speed needle and take off is sluggish, i tend to not like messing with the screws but will do what you suggested. Just to clarify, the low speed is the flat head screw that is just under or next to the high speed screw? Or is it the flat head screw that is on the end of the slide carb itself? Cheers for the help
1Likes
