Kyosho FW-05RR Forum
#16
Aliminium hubs are a great opption part too as the plastic ones strip under power.
#17
does anyone have a good setup for short tight technical tracks with medium-loose traction.
#19
what about stock setup but use black springs front and rear or laying the rears down to the bottom.
#20
ShAfTy you got PM.
#21
Tz engine
Hi racers.
Have any of u guys ran a os tz with the new team kyosho pipe. ive got it on my os tr and it hauls arse, beats os tz with eagle racing pipe up the straight at my clubtrack. i no that the tz i much more powerful and i think it would be awsome combination. im thinkin either os tz or sirio evo 3. leaning towords tz due to os reliability. the other car was V one rrr and mine is a FW05RR. the pipes are only made to fit fw series cars, They are not yet out for v one rrrs.
#22
My FWO5RR, JP 3 port, 37t ring gears,[IMG]img[/IMG] I'm running gold spring front & rear now and it seems better. JP
#23
Kyosho pipe
Hey zulu,
Thats the same pipe as wat im running, how does that go with that jp.
#24
does anyone use a geared or solid front instead of oneway? the track that i race on is short & has a couple of tight corners. i was thinking i could get a bit more out of the car through the tight parts with a solid front.
#25
diff
I have tryed all of them on my club track and i hav stuck with the oneway as it provides the best handling through the tight sections of the track. the solid has a bit to much under steer and the gear is not much better. ur track sounds similar 2 mine. u should try the gear diff if u are wanting to try 1 of them. wat engine and pipe do u run?
#27
i have the 3port tz & an rd logics pipe.
#29
I guess I should proof read my messages before I send them. Here is the corrected version
If anyone is going to race their 05RR at the WinterNats warm up next weekend or the winternats itself look me up. I am traveling to both and I may even bring my 05RR to see how it works on a big track.
JEFF
JEFF
#30
Originally Posted by ShAfTy
Hey zulu,
I also have carbon Vantage pipe which is good on my Novarossi but the kyosho pipe seems to suit the JP engine better.
