Team Magic G4
I'd say 37's @ 63mm with soft spring is giving you EDGE BITE.. Do the tyres chunk?
The Limes are very soft, and I would assume the car is rolling over onto edges of foams and biting as they are quite large @63/62mm.
The other thing that ALG pointed out was steering rate. Seems we werent the only ones to experience this. On slippery tracks we are losing front end grips hence the car understeers and we over turn / slip the fronts until the speed drops enough then they bite
We too solved a lot of snapping out of corners by reducing the steering rate on the car and the evidence is that when we race with more drivers, the track gets rubbered in and we get more front grip.
just ideas.. who knows what esle there is to learn!
for the rear belt im using kyosho rear rrr rear belt,the front using the kyosho front rrr...
hey guys iv been posting in the Team Magic G4RS 2009 tread regarding my team magic G4JS but iv been posting in the wrong area im trying to find out witch parts from TM G4RS,G4JR,G4+ evo and G4D will work on my G4JS iv been told that any parts starting with the number 502 will work on my G4JS but when i put it in the team magic website i only get replacment parts im really looking for hopup parts like carbon fiber parts and so on another thing is iv noticed that the k factory parts dont start with 502 dose any one no what they would start with ? i keep researching but i cant seem to find the answer im really looking for can some one plz help me out with this thank you.
http://www.rcshopping.com/profra.jsp...9574&pageNum=1
http://www.kfactoryracing.com/prolis...16151551-89574
http://os.3racing.hk/products_list.p...y=71&x=21&y=13
hey guys that helps alot ! thank you
Does anyone know if the clutch shoes from the 09 will work on th 08? I'm looking at reviving my car and I want to use the (K14208) teflon shoes and
(K14207) yellow shoe. If they work do I need the clutch plate (505043) also. I currently have the UFO clutch on it.
Thanks.
Thanks.
Im using the white teflon for RS08.. not sure about RS09 clutch.
Guys I still have the Original team magic g4RS not the RSII or 09 version I believe its called,
it is BRAND new never even mounted an engine in it I have a BRAND NEW not broken in ofna red dot II engine, do I still have a winning combo in a car? Are parts still easily available for it? or does TM still have the same US distribution issue from 2008? I have been away for 3 years and I dunno what's out there.
Should I sell it? has 1/10th on road improved at all since I left?
If I were to sell it what should I ask? once again it is brand new, I just built it and stored it.
hey guys i just wanted to make sure this k factory part will work with my G4JS # K1408 can some one help me out thanks
you can use it but the battery will be place under the fuel tank,g4s the battery is on the side of the fuel tank,and the rec will be next to th servo,back to old g4,
You can still get parts for these 08 G4RS cars, I believe Wolf hobbies are the US distributor and you can also get stuff from RCShopping as well.
It's not worth trying to sell it, i would just use it and try and improve your self as a driver. I have an Ofna JLR Evo 2 and it is a great engine and my best Picco thus far.
Enjoy your G4!
Andrew
Little blog of the TMs at the state titles earlier this year
This is a good read, good to see the boys flying the Team Magic flag and doing well.
Abbey has given permission to change project Mongoose to either G4+ or G4+ Evo.... Not sure which way to go, leaning towards to the + LE to be honest! Any thoughts will be appreciated!
Andrew
