Serpent 705
#871
Originally posted by modellor
I agree with you on that.
It is easier to get a 1:8th braking straight. It took me over 1 year to get my Yokomo braking straight with a one-way. The set up is extemely precise compared to 1:8th that I really hate it.
I know this may sound weird but I dont actually use brakes at all. Not even drag brake. These cars are not going fast enough to worry too much about braking and the tires are capable of adding enough sideways drag to slow the car down.
Also, besides making the car faster, using solid rear axle makes braking in a straight line better as there is no diff action between the left and right wheels when braking as the solid rear does not permit this. The wheels therefore do not unload due to uneven tire wear, uneven ground etc even when you brake hard.
I think that is why even on smaller and tighter tracks, some people prefer the solid rear axle because of this.
#872
Originally posted by markp27
It also seems that at first (when the car is travelling quite fast) the car breaks in a straight line, but then as it slows it suddenly spins out.
One trick I learned is to simulate ABS by tapping on the brake a few times to get the car to slow down quickly before a corner. Using ABS function in your remorte (if it permits) would do the job but somehow many people do not advise this as it wears the throttle / brake servo out prematurely. Also, you need to get off the gas sooner before a corner and brake a little longer. Braking at the last minute is a no no.
If you set your brakes soft enough, you might use to aid you in your cornering. Braking and taking a sharp corner hairpin at the same calls for a lot of dare devil guts and a lot of practise but once perfected, the cornering will be sharp, fast and very deadly The brakes when engaged will be very soft. Something like a brake fade...
#873
As for gearing, I'm not fully upto speed yet by any means, but already I think I need shorter gears, as I'm just say getting into second gear before I have to slow down on the quickest part of the circuit (do I simply exchange the gears on the bell housing to achieve this?) At the moment I'm just using the standard gears which came with the kit.
With a one way front diff, I believe it is more important to get the right gearing for the straights because the car needs to peak way before the hairpin corner (about 3/4 lengths before the hairpin) before you have sufficient time to apply brakes and set the car to slow the car down and glide around the corner.
#874
Originally posted by fmolzer
Wow, talk about a long and active debate started by a 14 tooth pinion gear.... I guess it goues to show that we are all looking for snappier acceleration. How about that german site that did 14 tooth gears, any chance we can get a link? And no, my buddy Salven never said anything about the price of gears, just wanted to mess things up a little... Know your comment about dutch/german numbers translation though, they say eight and twenty instead of twentyeight. weird. On the other hand, the US still thinks that inches and feet is a good system to measure distance.....
Anyway, sorry not Germany but Austria. In fact it's Serpent Austria. The link is as follows;
http://www.serpent.at/news/news.actionline.html
Scroll further down and you can see 14T first gear pinions and 17T second gear pinions.
#875
Originally posted by InitialD
The smallest pinion on the Centax is unfortunately the 15T. To increase acceleration further, you can change the internal ratio from the stock 2 to 2.136 by changing the side pulley from 18T to 17T, brake pulley from 23T to 22T and the rear diff pulley from 46T to 47T.
I really appreciate your thorough response.
#876
Originally posted by DSR
So, if I just run this set-up, don't I still have to change the 2nd gear spur & pulley? Also, will this set-up work without any necessary mods.?
When you do the above mod, the stock spurs (49T / 45T) can be left alone with the 15T/18T pinions (stock is 16T/19T). If you want slightly more acceleration, you can bump up the 49T 1st gear spur to 50T. It all depends on your track requirements.
If your track is that long that the engine runs out of breath half way down the straights, bump up the second gear pinion from 18T to 19T. This will give a nice jump in top speed. Make sure that the difference in the number of pinion teeths between 1st and 2nd is about 3 to 4 teeths to avoid your engine bogging down.
You can also change your 2nd gear spur by reducing it from 45T to 44T to get more top speed but note that changing spurs gives very subtle difference to the ratios. Changing pinions have a more drastic effect. Changing spurs for me is more of a fine tuning thing.
#877
Yes, you will not need any other modifications when you use the 22T brake pulley, 17T side pulley and the 47T read diff pulley. The rear belt fits the same. This is a Serpent approved mod
#878
The 705 already comes with the 22T brake pulley, correct? Also, I can't seem to find a part # for the 47T rear diff. pulley.
Would it be OK to run 15T/18T pinions, with 50T/46T spurs?
#879
InitialD,
InitialD,
The very first kits shipment of 705 have mistakenly have 22T brake pulley somewhere around Oct ~ Nov time frame. So, if you purchase after that, i would assume you got the 23T, you might want to check it first.
#880
InitialD,
InitialD,
http://www.mytsn.com/publ/publ.asp?pid=7186
#881
Originally posted by nizee
The 705 comes with 23T brake pulley. The part part number for 47T Pulley 808376. The 22T pulley is 808376.
#882
Thanks for the heads up, Nizee. The reference guide that came with my kit says that the pulley is 22T, #909242. Could this be correct? I got my kit in Februrary.
Anyway, as nizee mentioned, the kit should come with a 23T brake pulley (9616). Serpent actually intended to put the 22T brake pulley (909242), 47T diff pulley and the 17T side pulley in the kit. Somehow somewhere some parts got screwed up and they landed with the old pulleys back into the 705 kit. So somewhere between changing this, the parts got mixed up and some users reported that they had the 22T brake pulley which is only in the earlier batch.
Check to see and count it physically if you have 22T or 23T brake pulley. Check also if the diff pulley is 46T or 47T. The 22T brake pulley will pair up nicely with the 47T diff pulley. The 23T will pair up nicely with a 46T diff pulley. If your rear belting seems too tight, it could be that you got either pulleys wrong.
As for the pinions and spurs, all 1st gear Centax pinions (i.e. 15T, 16T and 17T) have the same diameter. The 2nd gear Centax pinions also are the same diameter (18T, 19T and 20T). The same goes for the 1st gear spurs (50T, 49T, 48T and 47T) and the 2nd gear spurs (46T, 45T and 44T).
Because of this, it does not matter if you pair up 15T/18T pinions (3 tooth split) with 50T/46T spurs (4 tooth split). They will mesh up properly. You can even use 15T/19T pinions and 50T/44T spurs if your track permits.
#883
I bought my kit in february too,, and it comes with a 22t pinion and a 46t in the ball diff....
#884
You can either keep the 22T and get the 47T to change the gear ratio and get gd belt fit OR you can call your country Dealer/Distributor to change for the part to 23T. Serpent had made the announcement on the mytsn.com that they will replace the wrong part.
#885
That is sad !
That is sad !
