Serpent 705
#3046
Originally posted by InitialD
You got it right bro... At least exactly what I thought about... However if you look at the touring cars that Team Serpent uses, they use the normal touring car body post. None of them uses the floating rear body mount meant for GTP / Lola bodies.
The problem with using rear floating mount type of bodies is that you are not able to use rear spacers on the rear uprights. I think you are only limited to a 2.5 mm spacer. That's about it.
I have one that I modified a little and use on my touring car bodies. It's on my Impulse PRO that usually gets a Lola shell on it. I thought it felt about the same though... Well, on smaller tracks that is. I would think on high speed tracks, the effect is felt more.
What I did was to shave off the small mount post on the floating rear mount as this is insufficient lenght to hold a TC shell. I drill a hole for a screw exactly at the spot of the old post for me to mount a new taller post.
I'll try out this weekend the floating rear mount on TC shells on my 705 on a high speed track and see the differences.
p/s: Before you remind me again or I get shot down by Mark, yes I forgot to bring pics with me... again. I'll try and remember tomorrow
#3047
Originally posted by markp27
Wepons set to stun! Hey InitialD, why not leave it until Friday? I don't have any pics this week and we don't want to leave everyone hungry on Friday!!!
Friday? Good idea Leave everybody hungry and feed them only on Fridays You're cruel...
Hey... You're the one with the D1 and you say you have no pics?
#3048
#3049
Originally posted by Que
Well the spacers are used to raise or lower the roll center for the rear? can't this be adjusted some other way?? and how does this apply to the use of sway bars?
The addition of spacers raises the rear roll center and makes correct cmaber changes in the rear tires. You can do this also by putting physical spacers underneath the rear bulkhead. Somebody suggested to put small lexan pieces
#3050
Bzzzzz
Bzzzzz
#3051
Ooophs, I forgot to mention that physically putting spacers underneath the rear bulkheads of the 705 may not be possible. This is because the side carbon graphite stiffeners that attaches to the aluminum X bar radio plate support will not be aligned.
I hear that putting the adjustable rear upper arms of the 950 on the 705 can make for rear adjustable trackwidth. Roll center spacers are also not needed. Talk about 950 technology on the 705
#3052
We're talking quality, not quantity
#3053
Ummm, OK, so it makes my job easier as I cannot post my non D1 pics then
#3054
Don't listen to him we want to see pictures!
#3055
Food for thought!
Just looking at the setup Michael Salven used at the Euro champs - the set up sheet shows by the steering block used "New"!!!
Looks like a new steering block is coming to the 705.
Cheers, Mark.
Cheers, Mark.
#3056
Initial thanks for the info on the overall gearing I forgot how it was done.yea the blocks that I used off my old car only had 2 races on them so they were almost new I switched to the impact and set aside the tc I loved the speed and handling of the impact with the Rb worlds motor I had on it.that was 3 or so years ago and now im back and the TC class has gotten huge so I went back to to tc
#3060
Originally posted by PUNISHER
Anyone see the mod Ralph Burch did to the rear up-right using an adjustable camber link on his car at the Sedan Nationals??
,, well that's not the only weird thing I saw,, in the first picture, seems to me that they shortened the wheelbase too!!
