Mugen Seiki Racing's Nitro MGT7
#482
Need a favor guys. I’m thinking about using the MGt7 2 speed for a custom build. Can anyone measure the distance of the 2 speed spread? Basically the center screw to center screw on the bottom of the chassis!!!! Thank you!!!
#483
Regard's
BM
#484
#485
I still need this if anyone is in the lab and wants to handle there car I’d appreciate it.
#486
#488
Hello people!
Has anyone tryed the front and rear drive trains from MBX8 on your MGT7 cars?
Any input will be appreciated.
Best regards,
Gerónimo
Best regards,
Gerónimo
#491
Not sure which grind you reference. The only one I've heard of is 'taking 2mm material off the front of the upper arm so as to shim it forward to reduce CASTER angle' 😎
#492
'8' parts on '7'
I got within 3/4 lap of him in B Main but he moved out to 2 laps ahead and bumped to A Main where he finished #6 out of the full field of 12. His car worked well and he can drive !!
The one thing I will attempt, is getting the newer '8' arms for the front. My MGT7 ran well for me. I had changed from my Serpent 1.0+ that has been my 'backup' since I parked the Kyosho. An extra round of 'qualifying' was just the situation I needed to find that at the very end of the 2 minute warmup, then 4 minute run, my car 'quit'. Found crank bolt had broken off. I had just got engine changed in Mugen so I could use it and ended up being able to run B Main.
Hope info helps...... (1st in A Main was a Mugen MGT7 with lots of custom tweaks by inventive driver/mechanic)
#495
hello, there are two mods you can do with the front arms. One is shave the front of the upper arms and shim forward and also shave the back of the lower arm and shim back all to reduce caster. Two is shaving the ends of the arms where the pivot balls go to narrow the front width of the car, you usually only need to do the bottom
