OFNA X3 GT SERIES
#181
#182
Hi guys,
Just a bit of an update from Australia. I have been driving a sample E car for about the last 5 weeks now and I can say I'm very impressed. It came standard with a 150 amp speed control and 2100Kv motor.
Our track is an old 1/8th scale nitro track but now we can only use E cars because of the noise complaints due to the impeding suburbs.
The Hong Nor power grip belted slicks with sweep pink inner foams and mounted on the on road rims from Hong Nor work the best. I usually get about 8 full 6 minute races with a set of these tyres and have tried nearly every other brand and they either don't work well or just simply over heat and go off.
This is a really good offering from Hong Nor and seems well built and rugged enough for long stints between maintenance.
The first night race ever at our track on Saturday night and Im off to check the setup.
#183
I just received mines today and I am impressed and I see a few things I want to upgrade in the future like chassis braces and toe blocks
#184
#185
Just don't like the same clutch bell. Going to see if I can use my Team C bell.
#186
#187
#188
It is true that the OFNA 2 speed is notorious for being very reliable, not to mention the plethora of spurs available. But the TeamC 2 speed is just as good. The OFNA bell with that small bearing isn't reliable compared to a clutchbell that allows use of bigger front bearing. I did try the 4 bearing solution when I was testing gearing possibilities. It works but still not remotely as reliable as the TeamC bell.
#190
Finally got a chance too get into the X3. I really don't like building kits anymore but I do go over the prebuilt ones. I like to start with 200k front and 60k rear.
If your the kind of guy who likes to go up and down your street. Diffs are filled just enough out of the box. Shocks guess filled with 800 so I left it there. I just set the rebound to 0. I had a couple of DM1 Spec for 2-3 years will say this car is an improvement without even driving it. Only dislike is there is only front brakes, tho looks like you can add rear.
I hope to put some tanks in tomorrow.
#191
Well ready to hit the track. I forgot about the RTR engine mount took me back many years to my bashing days. Will be the first upgrade for sure if available. I use a Werks 34mm clutch for GT. Very simple and hits hard or soft, whichever you prefer. My starter box reaches the the flywheel thats a relief. FYI Team C engine mount doesn't work.
To the Ohhh! police, my apologies if something is wrong.
#195
My X3 weighted in at 3438g similar to Team C. Xray 3998g
