Serpent 960....
#122
hi people
im new to your forum, ive been reading some of your post and since im a proud owner of a 950/r i thought i would say hi
i see Rookie Solara asking about this rear roll center convertion pack, i would be keen to see any pics of it if any of you have fitted it to your cars
later kris
later kris
#123
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Originally Posted by Marcos.J
look what i found in another forum!!
ken is the only person that uses the word "choco"
great job Marcos...Everyone beware......Choco is back....
here's why he was banned....
http://www.rctech.net/forum/showthread.php?t=36207
need more?...
http://www.rctech.net/forum/showthread.php?t=43091
#124
Wow just read that .... if it is that Choco guy ... what an a$$hole ....!!!!!!!!!!!!!!!
#125
Super Moderator
http://3hobby.net/modules.php?name=F...ic&p=7271#7271
#127
Originally Posted by kris NZ
hi people
later kris
later kris
This SUS1000 is kinda odd....ppl does know about it, but most ppl doesn't, cause this is not under Serpent typical parts # format (Serp 90XXXX)....Serpent website does not even list that, if you want it, you have to call Serpent-USA (yes, for once, USA does have something that others don't) and order it.........you cannot find that parts # or info on www.mytsn.com.......why? Don't know...
Anyhow, from several Serpent team driver that I have asked, the kit comes with modified rear bulkheads (right and left hand), an aluminum support for the front pivot mounting area, and a new aluminum backplate. The aluminum parts are balck annodized and have plugs that are interchangable for the roll center you want. The kit also includes 2 sets of 4 plugs allowing you to change the rear roll center either 1mm or 2mm higher than stock position. It also will allow you to run the stock setting if you wish.
So the roll center adjustment is applied onto the lower rear arms, along with the standard upper rear arms roll center adjustment, the 950R will have the full rear roll center adjustment like the 960R....they all said that it is a MUST HAVE for the 950R.
The kit is $99 USD....you can call Serpent-USA and have them to ship to your door....call and ask them and see they will ship internatinoal.
#130
I heard some of the New 960's will be running At the Great Lakes Race in Ohio. SHould be interesting to See them come to grips with the new car.
#132
The Serpent 960 will make its USA debut at the Great Lakes Challenge in Toledo Aug 4-6. I have my car together and what a nice piece. The car went together very well and they did one heck of a job designing this car. It looks like everyone that had issues with the 950R (which weren't that many really), they fixed it and went beyond on this 960! Nice job Michael Salven and the Serpent team for a well built car.
Brian Berry
Serpent USA Team Driver
Serpent USA
MEGA
Ellegi
KO Propo
Protoform
Fantom Fuel
Faskolor Paint
Brian Berry
Serpent USA
MEGA
Ellegi
KO Propo
Protoform
Fantom Fuel
Faskolor Paint
#133
Thumbs up on the documentation front, too!! Excellent job - surpasses everything previously done - well done guys!!!
Cheers, Mark.
Cheers, Mark.
#134
That is great news Brian. Thanks for the info. Look forward to seeing the car in a few more days.
#135
hello rctech folks. i couldn't find a 950 thread so i'll post in this section. i have a 950 team edition that i picked up 1.5 years ago. i've finally installed the motor and electronics in it. anyways, i was thinking about installing the pushrod front end and the lay down throttle servo kit. in your opinion, are these $$$ upgrades worth it? is there a markable difference. i really liked the pushrod on my veteq. just wondering if it's worth it for the 950.
thanks for your help.
chris
btw the track i run at is very flat, high traction, and very warm to hot summer temps
chris
