Serpent 960....
#1321
Originally Posted by going4#1
Chris, do you use the spacers regardless of positon on the shock tower or only when you mount them in hole '4'?
The 4th position is not exactly official but seems to be working for a lot of 960 drivers out there.
#1322
Originally Posted by Perez
Do you guys know what shock oils are equivilant to serpent..like Associated and Mugen ?
Did you start the build on your car yet?
#1323
Paul
#1324
Originally Posted by PMSorber
The name is Pieter.
Here it is. Other changes will be available within the next months.
Also notice the bodymount position and take care of the rear rollcenter inserts, they should be to the outside and downwards.
#1325
pieter or chris
what do you get more of when you use it ?
#1326
Suspended
Originally Posted by captian
pieter or chris
With the shocks down damper movement is minimized as well as the spring (less movement less reaction resulting in a stiff damper system). In general we see that it does not ad positive responce on curvey tracks. With the damper fully up (3rd position) you introduce more damper movement and more spring effect. What we see now is that this generates a jumpy car on tracks with high speed hairpins.
We tested this position a lot lately and it introduces more stability on the rear of the car. You know that the 960 is eager to break-out on hairpins. What you should do is to "loosen" the rear-end by several means.
This is one of three modifications to get rid of this behaviour, the rear end should follow the front in all circumstances. For the other two you have to wait ...
#1327
thanks pieter
will be looking for ward to that new info when you get it
#1330
wow, car is hooked up! spent most of the first qualifier trying to figure out the two speed and clutch. Second qual with setup. I qualified 5th , just behind Scotty Kimbrow (1st) , Jimmy jacobson (2nd) , Jim Adkins (3rd) and Thello Jordon in forth.
#1331
Fine Tuning
Hey Guys,
I am new to the 1/8th scale this year. Started with a 950R for a few months and now running the 960. I have the car pretty well dialed-in, but I am still having a bit of trouble with the rearend. It seems to kick out on me off throttle, near mid-turn, and more when on power exiting the corner. Here is my setup. I would like any input you guys might have.
Thanks!
Gearing - Spur 45/48, Pinion 16/19
Middle pulley - 24
Shocks - 45 wt 3 holes, purple springs front and 35wt 3 holes yellow springs rear, Fronts in the upper holes, Rears in 3rd lower position
Anti roll Bars - 70 deg front, 0 deg Rear
Tires - BSR 35/45 shore fronts 67mm, BSR 35 shore rears 74mm
Engine - Nova EVO6 - #7 plug and 30% O'donnell with a 8.5mm carb
Body - Protoform T530
Roll Center - Zero spacers upfront, inner hinge pin all the way down for the rear
Downstops - Front 1, Rear 14
Camber - Front 1.0 negative, Rear 3.0 negative
Ride height - 6mm Front and Back
Toe - Front 1 negative, Rear 4.0 Positive
Caster - 1mm in front
Ackerman - #2 long
Track Width - Front 253, rear 262
Thanks again!
Thanks!
Middle pulley - 24
Ackerman - #2 long
Thanks again!
#1332
Originally Posted by seabass2500
Hey Guys,
Thanks!
Middle pulley - 24
Ackerman - #2 long
Thanks again!
Thanks!
Middle pulley - 24
Ackerman - #2 long
Thanks again!
#1333
with yellow spring i had big problem,i put blue spring and the car was very good
#1334
Suspended
Hey Guys,
Thanks!
Middle pulley - 24
Ackerman - #2 long
Thanks again!
Thanks!
Middle pulley - 24
Ackerman - #2 long
Thanks again!
Try to changes your springs to red all-around or if this does not work change to Blue at the front. Put your downstops to 0 - 8 and if you need a lot of on-throttle steering to 2 - 7. Camber must be done based upon your tire wear, front must be flat and rear a bit of a cone (1 degree). Put your Anti roll Bars front and rear flat and then, based upon the ammount of available steering, play with your front arb. Use 45W 3 holes around. Toe-in Rear on 4? Change this to 2! Ride height - 6mm Front and 7mm Back. Try the WOS on the front of the car and also my small modification. If this stiil does not work, send me a PM.
#1335
Clay
Talk to one of us at the track. I have a couple of ideas for you.
