Serpent 960....
#1111
less roll and more traction,more stability when you're breaking
higher position with shochs will give more roll,lower is opposite
lower position will give more hang side
next time i'll go to the track i'll try the 2 positions,with the same set up,and i tell you what is the difference
you can try too....
mugen will make a tower where we can fix the shock like serpent(mugen copy )
you can try too....
#1112
Suspended
you can try too....
you can try too....
#1113
Then I understood it correctly.....
As I have the 950, I can not get my shocks that low, so I just have to live with it (I'm not gonna upgrade to the 960 yet....)
But in general the tracks in Holland don't give tractionroll problems...
certainly not at Groningen PMsorber...
#1114
Suspended
#1115
madbeats
have fun on sunday and put that 960 threw its paces
#1116
#1117
Its Ready too roll
Originally Posted by captian
madbeats
#1118
Originally Posted by madbeats
whut up Captian. i was out on Sunday but the 960 was in doors am waiting for the shell from J-go .. hope to make Serpent open day in July
#1119
#1120
you guy's are rite
Originally Posted by C Verano
You got to get out there and run it. Paint a white body for practice.
#1121
well i ran this weekend at cincinnati . ha lots of fun but the traction was up and down .so it made setup hard .
#1122
Hi guys, i wonder if 960 have the front universal dog bones for the car? I lost a set of front out drive and dog bone in a day. First, i hit the board and broke the front lower arm and that's for sure the out drive and dog bone will fly out but the second time i didn't hit anything and it fly out also. I had the front track width set at stock 252mm and did add the plastic white spacer in between the out drive and the one way for both side. Any help?
Thanks.
Thanks.
#1123
Thanks.
Thanks.
http://www.mytsn.com/products/desc.asp?prid=3702
Or you add an extra white shim to the outdrives. I suggest going with the optional CV's, you will never worry about a dogbone popping out again plus you get the option to use the wheel nut.
#1124
How did you end up finishing?
#1125
Chris ,Captian am going to take her out with some cones later this week ..
just get out there and get to know the car
