Serpent 960....
#616
thanks it's ok with a 9mm
#617
hello another problem
has anyone have a problem with side plate L carbon(903132)?
when my engine(RB C5) is on the chassis,i can't put the side plate because the engine touch it with the crankcase backplate's screw
what the solution??
i'm going to bore the side plate where the screws touch...
what the solution??
#618
what the solution??
what the solution??
#619
ok but there's a lot of material to take away,I fear to weaken it
#620
#621
ha nefastseven how did the build go . being you are pitting the engine in how did it go together for you
#622
Yes I had the same problem...seems like there are a few issues with design tolerances that Serpent overlooked. Too bad. I spaced the plate out to clear the engine by adding just enough washers to clear. Serpent again designed what they thought would be minimal amount of clearances to make it work but in the end it didn't. Front belt to steering servo saver is another example. While the car is great these kids of things should not be happening!!
#623
#624
1000mAh AAA packs are here!
Readers, the 1000mAh AAA packs are now available. Check out:
http://cgi.ebay.com/ws/eBayISAPI.dll...MESE%3AIT&rd=1
#625
Originally Posted by going4#1
Suggestion for Serpent: 2 Brackets in the bag. Surprise! Surprise! Not everyone drives a Mega engine!
#626
ok i drilled 2 holes for the C5's screw,but i think i will use a dremel to take away a little bit material,because the engine touch a little bit
i finished to build my 960 yesterday evening
it's harder to build a serpent than a mugen,with mugen all is ok nothing to touch,to drill or to take away
I always heard that it is annoying to build a serpent,i confirm that sound
but i'm happy to have this car,i think she'll give me a lot of pleasure on the track
thank you with all those which helped me
#627
what the solution??
what the solution??
The best solution is to countersink the rear cover plate holes and use flat head screws of the appropriate size to attach the rear cover plate. No grinding or spacing necessary for the stiffener. As an added bonus it is a little easier taking the engine in and out of the car.
This will allow stock unmodified to be used without weakening the integrity of the part.
#628
I've also heard that a Mugen really fits well, so probably there tolerances are smaller.....
#629
is this part essantial?
on the mrx2,3,4 there is not reinforcement
if we cut the side plate L carbon,is there a problem if i only preserve the tensionner
loke the drawing
loke the drawing
#630
Originally Posted by M7H
Thats why they are worn out earlier.....
i hope the 960 have no play for a long time
