Serpent 960....
#316
bodies
hi lewis here are the bodies. hope you like them.
#317
Great job!!! I like that... this will be my racing colors from now on
Chris thanks for hooking me up
#318
Originally Posted by C Verano
Did you have fun at the Nats? Are you going to make it to the Fusion?
Lewis
#319
Originally Posted by R/C Driver
I had a great time, yes I will be going to the fusion race this week-end are you going to be there ?
Lewis
Lewis
#320
Where is the fusion race going to be held?
#321
#322
Originally Posted by HELLOkitty
i noticed that the guys that were racing this paet weekend had a metal front roll center...is this a new part from Serpent?...kitty
http://shop.the-border.nl/product.ph...4&cat=0&page=1
#323
Originally Posted by border r/c
that's part nr 903161 on stock now already
#324
Buyer Beware
#325
That was quick..
I won't be racing the fusion championship this weekend my daughter has a basketball game on saturday but I will be going out there on sunday.
see ya
Lewis
#326
bodies
Chris
see ya
Lewis
see ya
Lewis
hi lewis did you get the bodies
#327
#328
Chris
see ya
Lewis
see ya
Lewis
#329
This is what you can learn (it does apply to 1/8th ONLY LOL):
Physical Forces and Setup - Theory and Practice_by James Hughes
"Steering Geometry
The steering geometry can be regarded at the movement and displacement of the front wheels as the steering wheel is turned. This movement is quite complex, and involves a number of different settings. There is one thing in common though, and that is the reason why we need a complicated geometry - We MUST lift the inside wheel while cornering.
The inside wheel lift is what enables a kart to go round a corner without using a differential.
Because of this lack of a differential, a karts natural direction of travel, forwards, is very difficult to change. This is down to the differing radii of turn experienced by the inner and outer rear wheels while turning a corner. The inside wheel is actually travelling a shorter distance than the outside, so therefor is needs to take fewer revolutions to go round the corner. However, the two rear wheels are attached by a solid axle, and must therefor move together, so in order to turn, one of the wheels need to skid over the track surface. In a car, the differential will allow the wheels to turn at different rates, without this skidding action.
This skidding action, or indeed the lack of it, is what make a stationary kart so difficult to turn round - you have to overcome the grip of one of the tyres, and with the sticky tyres used in many kart classes this can expend a lot of energy.
This is the reason for lifting the inside wheel and it effectively turns the kart into a tricycle during the cornering process! The steering geometry causes the inner rear wheel to lift off the ground while cornering, which means the wheel can rotate faster than it is passing over the ground. The rear inner wheel is no longer touching the track, and we therefor no longer need to overcome the grip from that tyre in order to turn.
In fact, depending on the power of the engine, we may be able to allow some scrub. For example, while a Prokart may need to entirely lift the inner wheel, because it does not have enough power to overcome the scrub, a more powerful kart may have power to spare in the corner, meaning that the power loss to scrub can be overcome. However, any scrub will start to cause understeer when entering a corner, so even though the engine may be powerful, it may still be necessary to completely lift the inner rear to maintain decent handling."
"Steering Geometry
#330
bodies
Not sure I haven't gone home to check yet do you remember if you sent them to the Santa Monica address or the Los Angeles address
