Serpent 960....
#2011
The Mugen Grand Prix in April at the Las Vegas Silverbowl. I want to go but i might not be able to due to unforseen reasons. What you been up to Scotty?
and yes i am allways board at work.
#2012
searching for 950 & 950r parts
I know this isn't the correct location, but I hope one of you 960 owners still has some good 950 & 950r parts they're looking to sell and keep a fellow racer on the track.
http://rctech.net/forum/showthread.php?t=153191
It would be great to get a used, but not used up 950r roller.
Anyone?
thanks in advance-
Eric Schutt
Anyone?
thanks in advance-
Eric Schutt
#2014
Originally Posted by SMcpot
Besides gluing the bearings in, has anyone found a solution to the excessive play in the bearing eccenters? I'd hate to plunk down more money on the aluminum versions if the problem hasn't been addressed.
Paolo
#2015
Originally Posted by Paolo M
Hi SMcpot, the reason because we use the allu eccenter is to have a little bit more tops speed. I run a lot with the plastic and i found no problem. I don't glue the bearings. Can you please describe where you have play? We are talking 960 rigth? One way or rear axle. Thanks
Paolo
Paolo
#2016
Originally Posted by Greg M
How do the alloy ecentrics increase top speed?
#2018
Originally Posted by nigelnuggets
With Aluminum Eccenters, the bearings stay more true and do not wobble where speed would be lost. By keeping the bearings true, and vibrations lessened the drivetrain can spin more freely. Although you may not feel the increased top speed, you can definitely see the results through a radar gun.
#2020
Paolo
Paolo
The plastic on this particular car is all new, as are the bearings and eccenters (converted to the 51T solid axle, as well). The bearings just fall out of the eccenters, with the slop being especially noticeable up front; the belt, also new, is somewhat loose in the default eccentric position and doesn't really give me an option to tighten it further since I will definitely have to have it at its tightest setting already. Just wondering if this was "normal" and if the aluminum eccenters maybe fit the bearings better.
EDIT: I'm having this problem with both the front and rear eccenters.
#2022
Originally Posted by Racer Z
Does anybody have the part# for the aluminum eccenters?
#2023
This is actually on a 950R, Paolo...figured I'd get more answers here since the 960 shares this part
Paolo
#2024
Yup....I contacted Serpent and they told me to send them in. But I find it unlikely that two pair of these parts bought at separate times could be faulty without more people having the same problem, so I figure that this is just the way they are and I'll try to make them work. Besides, I really want to run the car and would rather not be without them for so long
Thanks for the reply!
EDIT: I found that the 960 eccenters are not, in fact, the same as the 950R's....in case anyone else thought otherwise.
#2025
Hope this can help and sorry for the inconvenience
