Mugen MTX-3
#8656
Re: Hollow 2 speed shaft
Originally posted by rcmike
Hi, Who on- line,or can i call in the states that sells these?? THANKS
[email protected]
1-626-943-0897
#8657
EBAY
#8658
how do rubber tires work on the car? Stock setup???
#8660
mtx3racer - I doubt you can use the stock set up. The stock set up is for foam tires. You will need to make the car softer if you want to run rubbers. As it is rubbers have less grip. Go for softer springs and lighter oils. Tell you what maybe I will try to run on rubbers next weekend and see how it turns out!!! Lets both try and share some data.
#8661
Depends on what surface you run rubber on...
untreated - I believe that rubbers have more traction
Treated - foam baby!
G
G
#8662
mtx3racer - forgot to say that you need less camber on front and back for rubbers ... say 1 degree front and 2 degrees back is ok.
loosenut - I did see rubber running a lot faster than foam on a damp surface, after a light shower.
#8663
Originally posted by eddiethefish
Mine has all CVD. Can't afford to lose time to look for any bone.
i want to trade your mtx-3 with my daughter's bit-charger, it is much easier to hide and besides, you have no use for the mtx-3 anyways.
by the way, we are offically writing you off.
data
#8664
Originally posted by Data
you can change them all back to dog bones now, because i don't think you will run anymore. if you don't run the car, you can't lose them.
data
data
#8665
data
data
#8666
Originally posted by Ah10
I would like to take all his engines, tools! hehe!
#8667
shucks.. come on fish i pay for shipping plus $10 for all your engines and tools...
at least i pay for something.. not like those two..
#8668
I wouldn't mind taking the Kondo he borrowed from Data!
Give them back you PUNK !!!
#8669
fish:
so many malls, so little time............
data
#8670
i think he lost it.
that little souless punk !!!
