Mugen MTX-3
#6886
Re: mtx 3 springs
Originally posted by rcmike
do i understand this right....light blue is the softest rear spring for the mtx3 thanks i tried a search on here than went to mugen web site
From softest to hardest, Mugen springs goes like this.
Purple, Blue, Gray, White, Red, Pink (Rear only).
Being realistic. Much probably you'll never need something stiffer than a gray (white and upper are for 1/8 scale cars). Purple is usually used for people going with rubbers or parking lots, blue is the stock and is good on a 95% of the times, Gray is for those small percentage of times you need something stiffer.
#6887
I love eatting FISH
#6888
Re: I love eatting FISH
Originally posted by Varuth
#6889
Originally posted by Corse-R
Uhm.... probably are you like a shark then? A track predator who likes of eating little fishes like this.
The avatar you gave me makes people confused, I guess.
They probably don't think I'm like Bruce the Carcharoden carcharias.
I believe they think I'm like Marlin the Amphiprion ocellaris. Ruled out Dory the Paracanthurus hepatus.
#6890
#6891
Uhm..... I think that is an attitude problem... and your last avatars like the last you used (it doesn't helps to keep a right attitude). Go to the track and hunt some little fishes or much better.... beat a pair of 1000 pounds Makaira Nigricans. If they see you beating some kind of beasts he will think twice before teasing you.
#6892
Light weight chssis
Do you think it is better to have a very light weight chassis that is a bit more flexible, or the Mugen 4mm that is very stiff. I have an ETF motorsport chassis and I am trying to decide which one to use. What is the minimum weight for touring cars at the nationals. Anyone?
#6893
Re: Light weight chssis
Thinner chassis:
- Better grip on low traction conditions.
- More docile, because chasis is more flexible, but can be squirrely on high speed turns.
- Lower weight.
- Less heat radiation surface (chassis gets before 'heat soaked' - bad with high temps).
Thicker chassis:
- Less grip on low traction conditions.
- Car is more stable on high speed turns due to less flex on the chassis.
- Higher weight (but at the lowest point of the car, this can be an advantage).
- More mass for absorbing heat from the engine.
Tried the 3 and the 4mm chasis from Mugen and kept with the 4mm ones (feel the car better and more planted).
Minimum weight should be 1715Grams if you're using Personal Transponder, if not, should be 1700 grams (ROAR seems to follow the weight specs from IFMAR if not wrong).
BTW: Stock 3mm chassis from stock is slightly bowed (some PM me scared about this). At least on all the chassis I've seen is normal. How is yours 3mm chasis?
#6894
Re: Re: Light weight chssis
Knowing on which chassis will be better for yourself, only can be answered by yourself, check this and see if worths for you:
Thinner chassis:
- Lower weight.
Thicker chassis:
Thinner chassis:
- Lower weight.
Thicker chassis:
To me, if it works for him, that's fine. Probably suit best with his setup and driving style.
$0.02
#6895
I'm sure I'll lose tons of sweat for it. Perhaps, a lot more than from tunning an engine with/without WD-40!
#6896
mugen wheel alum spacer
part # please for the aluminum spacer mugen came out with about a year ago while the mtx2 was out.it was just a silver spacer that went behind the pin on the axle ,pkg had four in a pack and was about 5 bucks.i cant find a listing on any sheets or anything....Thanks
#6897
Re: mugen wheel alum spacer
#6899
Originally posted by B
anyone know where i can find an online list/ catalog of the hop up options from 5Stars?
i have looked but found nothing
