Mugen MTX-3
#5566
Re: Re: Re: hop ups
Originally posted by TBR
And they are made by GPM so the quality will be not so good
#5567
Re: Servo
Originally posted by Pepe
Hey Eddie, it's too early for a siesta!!
I fried another Hitec servo yesterday.... just before the main
I was using the Hitec HS945MG for the throtle and stop working... w/o a logic explanation. It is the third one in the last 2 years.
I am planning to change brands.... so i decided to ask you guys what would be my best option.
My steering servo is a JR 8450
Use KO, you'll never go wrong. I have the PDS-2143 for my steering and the PS-2174 for the throttle. Work out nicely on my Futaba 3PK and JR R-1.
#5568
hmm...where can i get that side belt conversion?is it any good,what is it good for short track or long?
#5569
#5570
Originally posted by Manticore
heard that stock shock shaft is a bit brittle.
#5571
Hello, the stain that you see on the piston is perfectly normal. It happens to fuels that contain castor oil. Castor oil has very high flash point that will continue to lubricate even at high temperature and they are necessary for all Novarossi, JP, RB, Picco etc,......car motors. However, the top of the piston, combustion chamber, exhaust outlet and the manifold will be black after a couple of gallons, they are a result of the combustion process, it is normal. If possible, please look at some other piston( not the new ones) that have had already gone through a gallon or two of another fuel(that contain castor oil for that matter) and you will see what I mean.
#5572
Originally posted by Corse-R
Better hop-up is the practice and a right setup of the car, none more needed.
practice, practice, and practice..
#5573
Originally posted by RClover
i've just replace my rear shock shafts hoping to stop the shock oil leaking.
#5574
Originally posted by eddiethefish
You should opt for the 24K Gold w/ Titanium coated like ours.
#5575
frankly speaking, i dont fancy gold color! this will make my car looks much older, do they offer other than gold?
#5576
the gold color coating (Ti) makes your shock works better, last longer and stop leaking !! it is just happened the color is gold. I cannot change it !
Manticore, love you, kiss kiss kiss...
#5577
#5578
I love MY FRIENDs. Where are you? C'mon out...
muah muah muah...
muah muah muah...
#5579
muah muah muah...
muah muah muah...
MY thoughts are that the Mugen CVD's are the only neccessary hop up part. The other parts are nice to have but really aren't needed.
#5580
having said that I do have other hop ups on my car.
OH, btw what is the part # for the square hollow main shaft?
Al
Al
