Mugen MTX-4
#5416
Originally Posted by factory racer
i live in toronto ontario ( IN CANADA) ....do you tihnk it would be over the winter time or just at the end of the season???
thanks
Mike
thanks
Mike
#5417
Originally Posted by asw7576
I was 4mm chassis freak before, but after driving how good 3mm chassis was ... I won't go back to 4mm ones. Stop hitting things and correct car setup is the key to drive better and faster.
TomB: increase the height of rear suspension upper link and add more front & rear camber by another 1 degree ?
#5418
Originally Posted by wallyedmonds
3mm chassis is easer to drive but it is slower , setup is key, i use 3mm and 4mm chassis
If you run a 4mm and really, really need more flex for grip, use the stock battery plate and put O-rings under the two rear top-deck screws. Just don't hit anything.
#5419
lol i use 3racing battery plate and 3racing uperdeck brace and instead of orings i use 2mm alm washers on the battery plate.but realy this car is way planted,oh and on the upper arm spaceing at the front im useing 3mm,im told this is way too much.
#5420
Lowering CG
Hey guys, in the pursuit of finding the lowest CG, has anyone tried or know of any detrimental effects to running the shocks inverted?
#5421
set up
can some one help me with a set up for the MTX 4 , a short track
#5422
Hi All,
I'm really starting to get frustrated with my MTX-4 no matter what I do it always seems to be stripping 2nd gear, I've checked two speed shaft and swapped changed bearing and engine mounts etc. But everything I've done has hardly made a difference. But I now know when the gears are stripping on the actual shift, it seems that as it shifts into second the pinion rips off a tooth on the spur, I have played with the two speed clutch and the engine clutch so if I could get everyones measurement on the engine clutch and setting on the 2 speed that would be much appreciated.
#5424
Originally Posted by jprevolution
Hi All,
#5426
I have slowed down my rate of stripping gears by being easier on throttle. When I wreck or get the car slightly in the air, by hitting a turn marker(raised asphalt) I dont immediately get back on the throttle hard. I noticed that when I was on the throttle hard as car settled down, I would toast a 2nd gear. I think my car would with a wheel or two off the ground and the force of getting that traction back would be more than the gear could handle
#5427
Hi All,
Dan
#5428
#5429
Hi All,
Read my earlier post, maybe 3 pages before this.
#5430
Hi all thanks for the responses,
I checked the engine brace a couple of weeks ago and found that it was slightly rubbing the cross brace across the engine. I re adjusted everything so there would be no more interference but I am still stripping gears, but the difference is now instead of stripping four teeth in a row, it now seems that it just takes one tooth of the spur at a time like it is just ripping it off on the change to second, I believe it is my clutch but Im not sure whether this would be from the engine clutch or the two speed clutch, any info would be great. I have contacted the mugen distributor here in Australia and he said this has happened to others and believes that if you tighten the spring all the way down on the engine clutch and than back it off one full turn than that should fix the problem, but I was at 1.5 turns and I am still stripping gears I will tighten all the way and see what happens. P.S this was happening on both Mugen and 3racing gears.
