Mugen MTX-4
#3061
Originally Posted by VenomWorldOrder
ay chook did i beat you with the bling factor?? my car is too nice to race now.
and here is my body for it its a blitz mazda 3
sorry to ask on the wrong thread,but i m asking on my X4
#3062
Originally Posted by MAVICXXX
tried on stratus 3.1 lastweekend,i still prefer protoform mazda 6.Have u tried on d blitz?how isit?
i put this body side to side with a proto mazda 6 and the rear end on the blitz is longer. this will either meen more downforce and less front steering, or if the front is good, good steering good downforce
the body is very stiff, if you look at the pics it has rdges on the botom front spoiler and 3 ridges on the hood. if you are a basher, on a budget i recon this body will last a fair while.
i'll post a report after this weekend. it is my first race with the 4!
#3063
Originally Posted by Corse-R
Hi Asw.
As you told it, needed to file a little the upper brace, but nothing that a quick pass of dremel could solve.
Regarding springs between brake pads, tried as many people on my MTX3 and MRX3 and gave us many probs (I tried with 1/12 front spring) and didn't worked at all, better to thinker a little more and with a sanding drum, remove a little the threads at the end of the screw (where the metal pad touches with the screw) to free as much as possible and ensure that brake pads doesn't bind with anything.
Agree, looks beefy and brakes much better (at least mine does).
Only MTX4 kind can do. I was refering to my MTX4.
#3064
Originally Posted by Scott Fisher
For all those guys that are doing the weight watchers thing going on here lately, I got to weigh my car the other day. We are getting ready for the Winter Wind Up race so I decided it was time to check the weight.
My car has the following changes compared to a stock MTX4
Mugen Titanium pillow balls
Skyline radio tray support
Skyline hollow steel 2 speed shaft
Kawahara 1st gear adaptor
Kawahara 2 gear adaptor
Mugen Titanium upper screw kit
Mugen MTX3 rear CVD's installed on the front
Mugen MTX4 rear CVD's installed on the rear
RC products 4mm rear shock tower
I was using the following servos both with aluminum servo horns. I have a Futaba 9451 on steering and an Airtronics 94737 for throttle. I used a Protoform Dodge Stratus. I measured using a hotmod Novarossi N12LL3 with a monotuning 11 fin head (stock head weighs 42g, monotuning head weighs 45g). I weighed it using Kawahara tires trued to 58.5f, 59r.
My car weighed 1695g.
With a personal transponder (8g) added to your car, you'll be 1703g.
Is the minimum weight requirement 1725g with transponder ?
#3065
I didn't list it, but my car already had the personal transponder in when I weighed it. I will edit my first post to reflect that.
Yes, the minimum weight with the transponder is 1725g. I added a pretty big chunk of lead to the chassis and put two nickels into the front bumper.
#3068
Super Super simple.
Remove the foam front bumper. Use a dremel bit (In the picture I showed the bit I used) to hollow out a cavity in the foam. Put the change into the bumper and reinstall the bumper.
#3069
I put in on the side of the chassis near the side belt. I am sure it is throwing off the weight balance, but it was the easiest fastest way to get the weight on it. I am going to look for a more central place, but in all honesty I am quite lazy
There is some space underneath the rear belt as well. may move some of the weight to that spot and maybe open the bumper spot to hold 3 quarters instead of nickels. If I can move the weight to the centerline of the chassis and put it front and back (I want more weight in the front to get extra off power steering) it will preserve the side to side balance and give me the extra front bias I want.
The pictures show where the weight is currently, and I tried to show that spot underneath the rear belt, but it isn't a great picture.
#3070
Originally Posted by Bad Mika
Hi Scott !
#3071
mine was 1763 when it was a stocker
the number will be slightly different from others because of different systems (electronics, motor, etc.) used.
#3072
mugen's coming out with the ninja and now they have this also.... another weapon!
#3073
i don't know if they are going to do the os21's only or 12's as well. but it will be nice to see a jp modified os 12 and hopefully the price will be a little lower than the nova's.
#3075
RC products 4mm rear shock tower.
AMB Personal Transponder
Noticed you are using tyres with a 0.5mm split of front and rear.
Just wondering whether you are using the 25T side pulley or still on 24T with overdrive setup ?
