SERPENT COBRA GT ENGINE CHOICES HELP!
#106
Hey guys, first off, i will start off by saying im glad to be a member of this forum and appreciate the great wealth of knowledge here. You guys rock!
Ok, on to the question, I am in the budget to buy a 1/8 gt car and i really like what i see in the serpent. What are some good engine choices? I've seen some people say that .21's dont have enough torque and .28's are too torquey and dont rev high enough? I'm confused as to what will perform well. I have a big block jato now with an os 21xz-r speed on it. I'm a speed junkie so i need something that will really get this car moving. I only bash around my neighborhood street but i dont care about the price. Here are what i've seen so far:
Novarossi Roma .25
Novarossi Keep on .21
Novarossi Flash .21 Rally
Novarossi 35 Plus .21
O.S. 21XZ-B Speed
O.S. 25XZ
O.S. 28XZ
If you have any more suggestions I will take those into consideration also. Thanks! You guys are the best.
Novarossi Roma .25
O.S. 21XZ-B Speed
O.S. 25XZ
O.S. 28XZ
I might be a bit late to the party here.... But for all out Speed and power nothing is going to match my modified Nova 28-7..... right now I have a few in oval racing and they literally eat the field alive every time out...We have smashed track records by multiple laps....... they have insane torque and the ability to spool well past 40 000 RPM carrying load........
car 1 and 2 are my mod 28-7..they go thru the other cars like pylons...these two cars went 1 and 2 all weekend, smashing track record and winning the event..... they are running against other modified 25's and 28's and just tore em up
+ YouTube Video | |
#107
+ YouTube Video | |
#108
Hey guys, finally got the car built and running. There's only one problem, with the 42021 header and 9886 pipe I cant seem to get the idle stable it keeps ramping up (novarossi roma 25 / os 21xz-r speed). When I make a pass, it doesnt idle down when i let off the gas. The idle just seems to "hang" until I blip the throttle and it will settle for a second or two then idle back up. I tried two different engines and they both are having the same problem. What gives? I've tried richening the high speed needle, richening the low speed needle, lowering idle.. nothing seems to work I am very frustrated at this point and dont know what direction to go. You guys are my only lifeline. Again, thanks for your help and support.
#109
oh yea, with the nova, i tried the wd40 method to check for air leaks and i sprayed it everywhere and noticed no difference until I sprayed it on the front bearing. It would idle down for a second every time i sprayed it so that engine is down for a bearing swap at the moment, but that still doesnt explain why im having the same issue with two different engines? Could it be the pipe? Could it be the flimsy carburetor return spring not fully closing the carb? Im stumped!
#110
Trying to put tuning into words lol
There are a few things I can think of… What are your temps? Get the engine up to temp and then run a tank through it. See how much that changes. Keep the car running if the temps are okay <250F (with body) keep monitoring the temp. If you have an air leak it will be plain as day, one second you’ll be lean and mean and then bam rich. Or this can go the other way as well rich to lean which is never too pretty. Temp is key and will tell you tons about what your engine is doing. As far as air leaks go keep in mind it can be anywhere from the fuel line/tank to the exhaust. Any potential for a change in pressure results in angry engines. One thing we do here is shoegoo the outlet on the fuel tank, if it moves around too much it will eventually leak. Last thought is check your idle gap. This is by far the biggest mistake tuning I have seen and accomplished many times myself. If the Gap is too big you are in for all kinds of frustration and heartache. Gap should be maybe the width of a credit card and then small adjustments (I do maybe 1/32 turns) from there. Remember more gap allows more air into the carb and will cause sporadic idling. Keep you adjustments small, its better to make multiple 1/16 turns than a few ¼ turns. The smaller turns will enable you to find that sweet spot on the engine.
Things I would do
-ShoeGoo the fuel tank outlet nipple
-Replace and check all fuel line (cheap and easy but can cause serious problems)
-Check all exhaust gaskets ( easy to crease or tear one and cause leaks)
-Run car like you would for a few tanks and monitor the temp, monitor how much smoke the car is producing. (this can be tricky, only make adjustments if you car is running hot, if its running cool keep going. If after a tank or more your engine won’t get warm then make adjustments to lean. Try and avoid making adjustments each time you temp, remember we are watching for sudden changes in the engine to indicate the air leak.
-Check you idle gap (make it small and adjust the low speed needle to get your correct idle)
Worst case scenario call Gus Wood and have him listen to the engine… How he knows what to do is sheer experience lol (probably not realistic to actually call..). He and Andy are the ones who have helped me learn many tuning lessons. Andy showed me the idle gap and how important that is. I tune regularly with Gus at the hobby shop on all kinds of engines, many of the tricks I have listed above come from him.
I hope something in this short novel helps you out! I have no experience with modified engines but I’m sure the concepts are the same. Best of luck!
Oh I forgot the easy one…. When you hit the brake make sure your carb stays closed before during and after. If you don’t have everything correct the carb will open and raise your idle speed after you let off the brake!
Things I would do
#111
I will inspect for air leaks first. That seems most likely my issue as it can sit and idle then all of a sudden the idle will "jump" up. the seal around the fuel nipple and also around the tank lid dont seem very good to me..
#112
Check your linkage.. With the engine off, but electronics and radio on.. Gas brake gas brake gas brake, etc.., while looking at the carb..
People always say change fuel line, tank, seal this, that, etc etc.. But usually I find it's something mechanical - bad linkage setup, or maybe a dodgy clutch or clutch bearing.. Or, just bad needle settings.. Always hard to judge these things online, but my first guess would be linkage, and second maybe too lean on the LSN... But yeah, could be a cracked tank or something too..
#113
#114
Ok I went back over all my linkages and added more spring pressure to the return side. I will test it later today.
#115
The low speed needle should be just outside of flush with the housing on the Roma.
Both of those engines should drop to a low steady idle.
Feel free to call for more details on tuning.
#116
In my Cobra I had something silmilar. I turned out to be a clogged tank. All I had to do was to spray the inline fuel filter of the tank with carb cleaner until the fuel flowed easily. After that the motor ran great. Another thing that I have found very useful to have is a Torque screwdriver. Most of use just go by feel on the head and other engine bolts and sometimes we either overtighen or leave loose the motor screws.
#117
It could be that the idle gap is too large. Close it until the engine idles lower, until it almost shuts off. Then run it around, and listen for the idle. If it is good, then idles high the engine is most likely lean on bottom. If it comes in good, and the idle drops its probably too rich on bottom. If the idle stays steady on the bottom it is close. When the idle stays steady, then adjust the idle gap until it is where you want it. It will take some fine tuning from there.
#118
#119
Not likely. Probably too rich on the bottom for the amount of idle gap. Factory settings are too rich.
#120
Ok I have the needles in the ballpark and it runs well. It just hangs after a pass once the fuel clears out. I can tell the tune is close getting light smoke trail and nice idle sitting there and throttle response is good. It just hangs after a run for a few seconds then it tapers off to nice idle. I can't seem to tune it out. Even with low idle and slightly rich on both needles it still does it. I may just leave it alone and try to get it to you to look at...
