SERPENT COBRA GT ENGINE CHOICES HELP! >
Old 09-02-2012, 06:03 PM
  #76
Team Kamikaze's Avatar
Originally Posted by howard85may
ok, i been looking at some high end servos, some high torque and some high speed. which one goes on steering, high speed? throttle, high torque?
High Speed for the steering and High Torque for the Throttle/Brake.
Team Kamikaze is offline
Old 09-02-2012, 06:08 PM
  #77
Default ENGINE CHOICE? How about this one?
Here is a Cobra GT I recently build for a customer, YES he is nuts!
Old 09-03-2012, 02:44 AM
  #78
Looking good! How's that keep on working out for ya?
howard85may is offline
Old 09-03-2012, 07:35 AM
  #79
What are you guys using for tires? Sweep, Ipanema, or Alpha?
Old 09-03-2012, 02:00 PM
  #80
mosaics12's Avatar
Sweep
mosaics12 is offline
Old 09-03-2012, 02:49 PM
  #81
Gary NJ's Avatar
Sweep!
Gary NJ is offline
Old 09-03-2012, 02:54 PM
  #82
san.'s Avatar
Trader Rating: 61 (100%+)
Originally Posted by mosaics12
Sweep
Originally Posted by Gary NJ
Sweep!
+1
Sweep all the way!
san. is offline
Old 09-03-2012, 04:41 PM
  #83
Originally Posted by san.
+1
Sweep all the way!
slicks or treaded for street racing? no track use at the moment.
Old 09-03-2012, 07:40 PM
  #84
I use a combo of both slicks and treads. I found that the treads hook up a bit better on rough asphalt roads but the slicks are the trick on smoother surfaces. GTs are my favorite and if you read the description on GT vs EXP you’ll know why. The treads also squeal when you lock em up. Kinda a funny thing but its cool on the track lol. Go fast! Sweep em all!
TerribleTy is offline
Old 09-04-2012, 06:21 AM
  #85
Ok I ordered the GT50 treaded with full faced foam inserts on black 6 spoke standard wheels. Should I have selected the new ROK wheels instead? How much better are they, will I notice a difference?
Old 09-04-2012, 10:20 AM
  #86
C-Trickle's Avatar
I haven't experienced the new ROK wheels yet. But I've never had a single issue with a Sweep wheel. The ROK wheels are supposed to be lighter, but you'll love those full face inserts.
C-Trickle is offline
Old 09-04-2012, 03:33 PM
  #87
For street use get threaded tires. Sweeps in hardest compound should be more than adequate for your purposes will last a long time.
Wachsmann64 is offline
Old 09-04-2012, 04:05 PM
  #88
As long as you got the new GTLS insert you are good to go. This new insert makes the tires wear significantly better. I have a few weekends on mine and they still look like scuffs. I haven't tried the ROK yet either, they are on my radar though!
Old 09-04-2012, 05:10 PM
  #89
finally got in touch with Sweep Racing USA and got them to change my order over to the new ROK wheels, GT50, and GTLS full faced inserts! Go Sweep!
Old 09-04-2012, 05:16 PM
  #90
Ok gents, need to pick your brains on battery selection.. So I have the futaba bls351/451 and they're rated at 6 volts. I called futaba customer support and they said LiFe was safe to run as long as the nominal voltage is 6.6 volts. So, my question is, what kind of capacity should I be looking for as far as MaH rating? Also, how big of a battery will fit this car? As always thanks for all your help and time, you guys ROK!
