How to: Saucing foam tyres 1/8
#16
75%-100% rear
50% inside front
is a good starting point
I run most of my practice without it then my final practice i go out with it.
for most runs I put it on as soon as I can and work it into the tire.
I have a tire saucer but have only used it once this year, its not a must have.
seems difference sauce works at different tracks we are limited to one brand where I race most of the time.
50% inside front
#17
I don't understand the concern....wouldn't it be easy to tech the cars to see who may be using sauce prior to a race? (of course, where it's not allowed).
What would be the benefits of using a tire saucing machine as opposed to simply putting the sauce on and then rubbing it off 15 mins later as we used to do back in sedan foam racing?......saw these machines online and have been wondering what they were all about.....
When you rub it in get harsh with them. When you wipe it off use force. Nothing sucks more than wasting all of your warm up trying to get your tyres hooked up.
#18
My friend told me now that he sauced a set of tyres with the machine a couple of days before he used them. This way the additives are penetrated deeply into the foam and the tires were not "wet" anymore when he puts them on the car.
He told me that it takes 20min per set. The latesst saucing machines do now have a light bulb integrated which is meant to apply heat as well. Obviously this helps with penetration also, or is meant to dry the surface after the treatment. Crazy and pretty time consuming...
#19
My friend told me know that he sauced a set of tyres with the machine a couple of days before he used them. This way the additives are penetrated deeply into the foam and the tires were not "wet" anymore when he puts them on the car.
I tried saucing on 8th scale after the WC in Miami. It was obvious that ALL of the top cars were saucing. Wether the tires were done at the factory, or there...not sure. I know slower drivers than me with "good tires" passed me on the outside of every turn. My car was at the limit, theirs looked super stable, and easy to drive.
Only difference. Sauce.
I see no way to regulate it. I can sauce, and you can not tell. Even under close examination of the tires. No smell, the tires just make more grip.
#20
So the next thing is: "Which sauce to use"?
My friend got a product from an international top driver. If I remember correctly, the bottle is labeled as "Reinhard diff oil additive"
Surprisingly enough, it works very well...
#21
I "heard" at the Worlds a lot of people were using LRP Blue? I have only tried that and the Zero Gravity stuff. Put on by hand with the applicator it came with. I can tell you if you don't get it rubbed in real good warm up you will be a hazard and think your car is broken.
#22
Everyone seems to want to keep this information to themselves.
#23
Im not telling anyone. lol
#24
#25
I Avoided saucing till earlier this year but after trying it I even had to build a tire rotisserie mainly to keep the solution off my hands and I'll be damned it did seem to work better , then had to build a couple more machines for friends and at the Midwest race had enough inquiries that I built a small batch , have some left and will have them available at the GLC _ PM if interested.
#26
Can you post any pics?
#27
Something like this
#28
#29
This is a one time production only.....
#30
