Kyosho Inferno GT, GT2 Race Spec
#1291
Thanks again nick m. I found the gears, what seems to be the problem with the helical cut gears, other manufactures use them, are the kyosho ones a weak material?
I still can't seem to find any k factory hinge pins from amain in fact when i click on k factory in "all brands" there is only one product. There are many similar types of hinge pins by other manufacturers for their cars but nothing specifically for the gt2. At a bit of a loss here other than trying to trying to see if a set will fit from another vehicle maybe.
I just found some racers edge (k factory) pins on amain but they are discontinued.
ok edit again, I may have found some at a couple of places but I will need to confirm with them they are actually available as they seem to be becoming extinct.
#1294
#1295
too true danyvw, I am having a hard time getting some, I found some at rcboyz, went to checkout and noticed postage was $135usd + $39usd for the pins = $174usd = $246aud another place wanted $40usd postage = about $85usd, postage will have to be a lot lower for me to justify buying these, still looking but it could be e-clips for me
#1296
#1297
m 2 racing-sorry m2 c racing
#1298
i was also looking couple of years back to change the e clips but finally i did not to both of ny gt2 ,ofcourse the 777 hinge pin set is better if you are litle crashing the car ,,,oups or if you are assempling and dissasempling tha arms ,in the beginning of my driving experience i was loosing the e clips because of crashing accidents ,after a while and with better experience i dont mesh with them any more,what gears are you using at your gt2.-,_:
check also some solutions from this company,http://m2cracing.com/searchquick-sub...?keywords=2510
#1299
At the moment I have only the stock gearing and as its currently the old 2 speed setup, I believe the gearing will change once I get the new 2 speed.
Yes I have seen the m2c stuff thanks nick m but I can only see stuff for the st-rr, will these fit the gt2? I think I had asked them some time ago and they said they wouldn't fit but I may be wrong.
#1300
here is a comment from an other thread .The other thing that I found that really helped handing for this car is the M2C front anti-dive kit http://m2cracing.com/product.sc?prod...&categoryId=82 . The GT2 is built with a lot of caster in the front. This jacks weight into the inside front tire when the car is turning. This jacking causes the rear inside tire to be lifted off the ground making the car loose from the middle of the turn to the exit. The M2C front anti-dive kit has different inserts that can be put into the A block (the one at the very front of the car) so that you can minimize the amount of total caster which makes the car have better corner entry with much better rear traction from the center of the turn out. I ran either the 3 dot or 2 dot down inserts in the A block. This M2C anti dive kit is the best performance upgrade available for the GT2 in my opinion.
also fit the gt2?
#1301
I was looking at those too, obviously they fit the gt2, so does the rear toe block system
also fit the gt2?
also fit the gt2?
#1302
#1303
I find that 17/21 is good for a +.21 (.25, .28 or .30) but too tall for any .21 engine, for a good revving .21 a short gearing is better, most of the time 15/19 will do the trick.
#1304
sometimes depends from the track condition its true dany 17-21 might be long gearing ,me myself cause i modify my engines i use even 18-22 ,last test i tried with flash 21 pt and yes this one wanted 15-19 ,with 7 port rally modified and if i dont destroy the engine ---yes i have destroied enough--17-21 works fine in long tracks and specially in oval track,today i also tried a modified off road toro nero with efra 2052 ,yes call me crazy it was a stupid project but finally after mofifing the crank the sleeve and with 8.5 venturi the torque of the engine was totally spining with 18-22 ,even stock some people say the off road 7 port from nova is good for gt2 cause they have enough torque
#1305
