Kyosho Inferno GT, GT2 Race Spec
#436
spur gear
Does anyone know someone that will make a 40 tooth spur for the new transmission for the GT2 RS?
#437
I was using 43/46 in the B Main and managed a 2 lap win over 2d but in the qualifiers there were too many cars spanking me on the straight. I had an hour to the A Main and answered the menacing little voice in my head that keeps me using the 'old style' clutch so that I have the option to 'run tall'. I put in my 40/46 and found the 'drag race' quite exciting although the incredible speed just hastened the demise of my old set of tires.....did not bode well for cornering but I am still enjoying the 'mind video' of the speed on the straight.....worth the experiment.
#438
Are you asking that because you saw my Kyosho GT run 40/46 at the Airtronics Race in L.A. this past weekend????
#439
I saw in an earlier post that someone has used REVO springs with great results on their GT's. I wanted to know if anyone has used these from rc4less:
http://www.rc4less.com/product_info....9b6fc483cff892
And if they had a positive or negative experience with them. Thank you.
#440
revo no no
This brought to you by guy with 'cheesy grin'........1st place B Main GT, Airtronics Grand Prix, L.A. ......
#441
Drive shaft availability
I'm retro fitting a GT1 chassis to my GT2 (with 'new' transmission from Kyosoho) and trying to come up with a part number for the front drive shaft....
Nothing I have Kyosho GT wise works - all are too long. I was digging around in some old Inferno parts that I have and came up with a shaft that fits - but it's smaller in diameter. Obviously NOT sure what effect that will have so I'm still looking for the correct one. IF my memory serves me correctly, the 'new' transmission takes up more space, therefore I'm not even sure if a 'stock' GT1 shaft will work....
Help!!!!
Help!!!!
#444
hi guys i'm new to this site and i like a lot of experts on this thread mmm well recently got my inferno gt2 race spec and im thinking to keep it stock for now the only upgrade i make is the motor i got a axial 28rr and i was wondering if that motor will be fine for my inferno ??? thanks guys *carlos*
#445
(1st bump from B Main to A....Airtronics GP in L.A. GLARCC...GT8)
#446
The Axial .28RR2 will be much more power than the 'stock brakes' and those stupid tires on brittle rims will be able to handle. I've used the Spec1, 2S, and the RR2 with great success. The engine will outrun your brakes and unless you get some 'performance tires', you'll be eating curbs. (I like SWEEPS)
#447
Well, it's meeeee again......
Honestly, this car WILL get together eventually.... Now to the front chassis brace - interferes with my dual front brakes....
Solution??? I've considered removing one of the brake discs but that seems a bit extreme; the chassis mount is too tall and interferes with the front disc. I can't see raising the transmission as a solution.
Low profile front brace mount???
Does the original GT even HAVE a front brace - doesn't look like it in the exploded drawing I have but there's a hole in the chassis for it AND it prossibly would work with the 'old' tranny.....
Tie front plate to the tranny plate???? Looks possible but way too complicated....
Re-drill the front brace mount on the chassis?? Another possibiility I guess.....
Help!
Help!
#448
Help!
Help!
Are you saying that your 'dual brakes' are both on the front end of the transmission?? I've seen that detail with the older 'fiber pads'. You need to get a set of the 'bonded' brake pads that work really well in a single setup. I've used those with the 'special' disc or the 'stock' metal disc. The 'special' brake dics is the only one i've ever seen 'blow-up' on my car.....so, the stock discs work just fine. You just need the superior function of the 'bonded' pads. One set of brakes works great and has great adjustability for your driving style.(remember to use ballpoint pen spring or such to keep pads off disc for cooling..and 'smooth shoulder bolts' so that disc pads don't 'hang up' on bolt threads)
I've 'tweaked' enough chassis to be able to say .....yes, use chassis braces.
There IS a chassis brace that ties the front diff area to the transmission top plate but I couldn't find it in my 'bookmarks'.....I'll look again and check if that was for a 'short' or 'long' chassis.
#449
this special brake pads ( bonded pads ) have superior performance against the original ones , and a single brake system gives what youŽll need ....
http://www.amainhobbies.com/product_...e-Pad-MP777-WC
this ones ok
Guga
this ones ok
Guga
