Kyosho Inferno GT, GT2 Race Spec
#1576
What gear else than Evolva ones fit on the VS058 clutchbell? Looking for a 16t first
#1577
Also, can someone confirm what is the pitch of the IGW008 spur gears? I'm getting a bit confused, I've read here that the pitch isn't exactly the same as the Evolva gears. I am using Evolva 16/19 clutch bell gears (seemingly without issues) but I'm getting the feeling they aren't exactly the same pitch (because the stock clutch bell gears look pretty different on pictures)? Which 16/19 gears would fit VS058 clutchbells (because I've got a few) and have the perfect pitch for the IGW008 spur gears?
#1578
What bodies worked best on the gt2?
#1579
#1580
Installed the IG111 clutch bell to go with my IGW008 2-speed, in order to get a perfect mesh. It immediately started spinning freely. I had my doubts about the non-threaded 2nd gear but didn't wanna put any glue on it because it isn't mentioned in the manual. Do you guys put CA glue or anything?
EDIT: Kyosho answered my question, you have to make sure the beveled side goes towards the first gear and the flatter side to the clutch bell, which I didn't do. Works perfectly now
#1581
Hey guys, hopefully this is a reasonable place to post my question.
I have a custom project using the Kyosho shoe-type 43/46t trans. The clutch bell is the matching 15/18t.
I'm a little lost in the kyosho lingo, could someone point me to 18t 1st and 21t 2nd pinions for this bell? Or is this not really "a thing" in kyosho land? Thanks!
EDIT:
Is it common to run a 4 tooth spread on the pinions even though the transmission is a 3 tooth spread? Because 17/21 would be even better to maintain a little more low end.. thanks
EDIT:
#1582
EDIT:
EDIT:
You can also use the fw05 clutch bell (vs058) and the evolva gears (fm540/541) or only the 1st gear evolva pinion and 2nd gear ig113 on the original bell. I use the 16/20 or 17/21 with a lrp zr.30x and mielke efra 2041 turbo pipe to tame down the low end and get more top end in my Inferno GT2 Type-R EVO . What is your custom project? In which chassis you want to use the gt2-trans?
One tooth difference is no problem. The 17/21 combo is a tight fit, also you have to modify the tank post a little bit to fit the pinions (if you using them on Inferno GT2).
#1583
The Pinions for original clutch bell are available in 13-15T (ig112) and 16-21T (ig113), also the 2nd gear pinions are not threaded on this type of clutchbell.
It sounds like 17/21 may work for me.
My project is not an Inferno. It's not even two-stroke.
Here is a video of my project if you are interested:
+ YouTube Video | |
#1584
Great information, thank you!
+ YouTube Video | |
I am glad to help you out. If you want to use the vs058 clutchbell, you will also need a 8x12x3.5mm bearing, 8x12x4mm will also work with a little shimming. Are you using the stock 15/18 pinions in the video? What kind of engine is that?
#1585
The engine is an O.S. Fs62-v airplane engine. Not a big powerhouse compared to the 2 strokes we're all used to, but it's definitely an interesting build!
#1586
I've been told Mugen or Xray 1st gears work but I haven't been able to try them. Anyway I'm covered with 15/18 and 15/19 on the tracks I visit.
#1587
I believe this is not fully correct. Yes, the Evolva gears work but the teeth are not the same. I'm in the same situation myself, as I'm using the IGW 008 2-speed in a custom GT project. Evolva gears work but the gear mesh is much better with the Inferno GT gears as the teeth are shaped for the IGW008 transmission. I though they were the same but when you compare the two, they clearly aren't. I also went through a few plastic gears (very rarely, but it happened) but when I switched to the original GT clutch bell gears I haven't stripped a gear since. Kyosho should really make a IG112 16T first gear.
#1588
If i remember correct, there are also the colorful anodized HPI Nitro 3 pinions (modul 1) that could fit.
#1589
Yep, the evolva and gt pinions are not exactly the same, but they work. I have two vs058 clutchbells with 16/20 and 17/21 mounted pinions. Using the 16/20 on the igw008 2-speed with little to none backlash for over 2 years now without any damage to the spur gear. Gearing options are fine, i can choose from igw008(43/46) with stock 15/18, 16/20, 17/21 and the old style transmission with 40/46-spur gears and 15/21 pinions giving you a fdr of 6,3:1 and massive top end.
Just to clarify, if you do not mind.
This evolva 17t:
https://www.amainhobbies.com/kyosho-1st-gear-17t-kyofm540-17/p27402?gclid=Cj0KCQiAyszSBRDJARIsAHAqQ4qPxFrrLaxte 7eQHYdpGkG0rLslZvk-5M2pyJTCe7mj55_cbq7pZjsaAlh-EALw_wcB
And this ig113 21t:
https://www.amainhobbies.com/kyosho-2nd-gear-21t-kyoig113-21/p29010
Will fit the stock ig111 bell and mesh well enough with the 46/43 transmission regardless of the different tooth profile on the first gear pinion, and the fact that the pinions are a 4 tooth spread instead of a 3 tooth spread?
Sorry that I'm asking to have this information fed to me, I just don't want to have to order things twice.
#1590
One tooth spread is ok, but i didn't tried the evolva and gt pinions mixed on the original bell, so no experience. However, i can recommend you getting the vs058 fully threaded clutch-bell and the evolva 1st and 2nd gear with some shims. Dont get me wrong, it could work even with the HPI pinions. I am in the process of rebuilding/tuning my gt2 soon, so i disassembled it to maintain and used some parts of it for my electric gt2. Here is a photo of the engine and the clutch bell using 16/20 evolva gears with the vs058 bell.
