Originally posted by blur you will be surprised what ntc3 + can do :sneaky: :sneaky: :sneaky: |
Originally posted by SCIDA Do you have the two speed yet? Very important for racing. If you buy a rear exhaust engine make sure to get the new Team Associated pipe with it. |
Dont forget also to try some of the "free" adjustments to get a bit more speed out of your NTC3
Things like castor, camber, and toe etc are all easily changed and can be a big help in lowering your lap times. Cheers |
Originally posted by tommi Apart from what a car can do, the hand and brain still play a major role; and I'm impressed by yours! :nod: ;) |
Stick with the stock engine untill you are happy with the handeling of the car. Adding more power will make any handeling problems worse.
The Fix, threaded shocks & side brace should be all you need. Your track should have a class to suit .15 engines & RTRs so practice your driving & set up while saving your cash, then when you are ready for more power upgrade to a hi performance .12. Have a read of the NTC3 thread & you will find plenty of info in there. BTW the RD pipe does not work well with all engines. I like it with a Sirio but the Werks pipe is much better with a Rody. The AE duel chamber works fine for most applications as well. Dynamite is best left on the hobby shop shelf. It is a great car when set up properly, get the XXX main or Hudy set up guide & experiment with adjustments, this will make you much faster than any bolt on upgrade. Have fun:) |
And of courese you will need the correct tyres to suit the track.
