Pinoy Racers
#211
Engine Problem
Hi mga peeps,
Patulong naman sa engine settings. Kapag start ko kse yung GS15R ko na engine namamatay sya kapag tinatanggal ko na yung Glow starter. Ano ba dapat ang baguhin ko? Ang current neddle settings ko are:
HSN: 2 1/2 turns from close.
LSN: 2 turns from close.
Idle: Carb is 1 mm open.
Salamat.
Salamat.
#212
Location: batang kalokohan! ay kaloocan pala!!diretso ka lang,pag nasaksak ka! bahay na namin yung sa harap!
Re: Engine Problem
Originally posted by Bushwalla
Hi mga peeps,
Salamat.
Hi mga peeps,
Salamat.
#213
Re: Re: Engine Problem
Originally posted by kyoshoBOY
palitan mo muna ung glowplug mo and then start again.
Salamat sa mabilis na pagsagot. Kapapalit ko lang ng glow plug. Ano pa kaya ang pwede kong baguhin?
Mabuhay.
#214
Bushwalla,
pahabol after changing the glow plug namatay pa ang engine try adjusting a little bit the "idle"
#215
Originally posted by rice
Bushwalla,
Bushwalla,
Kinalas ko yung linkage...para madaling ayusin yung low end needle at idle needle. Di na namamatay yung engine kapag tinatanggal ko yung glow starter.
Ang problem ko naman eh di ko ma-idle yung car. Yung LSN is 1 1/2 turns from close. Tpos habang naka-set to neutral yung carb ina-adjust ko yung idle needle counter-clockwise (loosen) para sana makuha ko yung settings para mag-idle yung car. Pero umaandar pa din yung car (gears). Ano pa ba yung dapat kong i-adjust?
Salamat.
#216
Bushwalla,
by adjusting the idle needle from counter or cloclwse u can idle ur car or stop the gear from spining. dats the only thing u can do to dat prob. and also try checking ur linkage if its in neutral position "the carb is properly place or at idle position".
#217
Dens!
Eto ok lang.
soft springs na gamit ko, tapos 10k n ang diff oil ko.
Un bang sinasabi mong porma ng shocks, di ba ung shock sa likod, may pinagkakabitan ng screw sa taas, bali 3 hole un ung una ang porma ng shocks upright sya, tapos ung huli medyo naka parang 70degree ung shocks.
dun ko nilagay ang shocks sa 70degree.
O ung tinutukoy mo ung nasa baba?, may 2 option dun kung up or down mo lalagay ung screw.
Alam dens konting dulas na lang talaga ang problema ko, kaya medyo pigil ako sa throttle, hindi ko maitodo tulad nung nakarubber ako. pag na solve na to, ok na,
nga pala ung engine ko ok na..
tnx sa yo!
more lap time speed!
tnx sa yo!
#218
bulletdays
pare subukan mung lagyan pa ng camber or bawasan mo ng droop suggest ko lang
nelly
nelly
#219
Bushwalla,
Bushwalla,
HSN: 3 turns from close.
Idle: 1 mm carb opening. I tried playing on the idle settings but still the car do not idle.
Thanks in advance!
#220
Bushwalla
recheck ure clutch engagement put some shim between the clutch adjustment and the inner bearing housing try that
#221
Originally posted by dg8one
Bushwalla
Bushwalla
#222
#223
Mga Kabayan,
Tanong ko lang kung Magkano yung Xray T1FK sa Pinas at san shop ang nagbebenta??..
Anong servo type ang gamit ninyo sa MTX 3?? High torque for steering ano ang recomend ninyo??
Salamat!
Salamat!
#224
ok lang yung kabayan
sino ba dito sa inyo ang pupunta sa national sa texas
#225
