Old 08-17-2013, 10:36 PM   #631
mazzeo wins!!!!!!mark green 3rd!!!!!!!!!!!!!!we truly have a great and balanced car!!!!!!!!!!!!thanks to rcracingtv.net !!!!!!!!!!!!!!
Serpent 748/Nova Virtus/Sanwa M12/Maxima/Savox Brushless/Xceed
GPXJOE is offline   Reply With Quote
Old 08-17-2013, 11:28 PM   #632
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Default 747 belts
Fellas I'm putting in a order! Should i get the regular belts came with the car, or should i get the Low friction? R the low friction one or two race belts? Or should i get the orange belts? Or a mix of them all?
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 08-18-2013, 12:24 AM   #633
It took me 30 playing days, 5 of them are races, before my center belt lost a tooth.the regular one.
I just switched to the low friction just now. Point is, the regular ones are very durable.havent raced completely with the low friction ones yet.will let u know.
Old 08-18-2013, 05:02 AM   #634
Aza088's Avatar
if you set your belts correctly (not too tight or loose) and clean your pulleys regularly your low friction belts would last months.
My last set i took off over the weekend had been on the car since April!
We race 2 times a month i missed 2-3 races, when we race we do practice 3 qual and 30min final. plus some testing and engine running in as well (i only changed them because i thought they have to be getting close to there EOL.)
Some guys like the peace of mind with the standard belts although i have never gone back once i started running the low friction.
I do mill the chassis at the front so the belt doesn't rub i also take a little off the rear hinge pin mount so the rear doesn't rub.
Grab the low friction IMO.
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 08-18-2013, 06:08 AM   #635
lil-bump's Avatar
Trader Rating: 83 (100%+)
Originally Posted by Aza088 View Post
Never had much success with the holes cut in the bumper but is on my list of things to test again.
We run the long springs with the shock extentions and have had great success
I never tried running the long springs with the shock extension. That should work. I milled my chassis in the same places. I run all low friction belts. My last set been on the car since June.About 5 races.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-18-2013, 11:29 AM   #636
Thanks for the info! Low friction it is then........
Old 08-19-2013, 12:56 AM   #637
Serpent007's Avatar
Yup +1 low friction belts for me as well
~Serpent 747 -2013 upgrades~ 2013 REDS Racing M3-WCup Team Tuned Engines~
~2013 REDS Hipex Mr Tuned pipe set/s~ Savox~ Spektrum~ Enneti~ SRS-N/P37~
-- BSP "Ben Sterling Products Melb" --
~~~BIG THANKS TO "WALTER HOBBY RC" 4 LOADING ME UP WITH GOODS!~~~
Serpent007 is offline   Reply With Quote
Old 08-26-2013, 12:37 AM   #638
rias5037's Avatar
Hi, anyone know if a 733 or even 720 receiver box will fit the 747, i rather add a few grams then risk having my receiver damaged.
Serpent 747, Max .12 xxl3, Nova 2630, Contact-rc.
rias5037 is offline   Reply With Quote
Old 08-26-2013, 07:41 PM   #639
The old 720box thingy fits, if u can find one........733 a no go!
Old 08-26-2013, 07:46 PM   #640
Default clutch weights left hole or right hole??
Fellas quick question, if u put the clutch weights with the left hole on the flywheel pins is that a more aggressive clutch??
Old 08-28-2013, 10:15 AM   #641
lil-bump's Avatar
Yes, The left hole is considered leading weights(more aggressive). The right hole is considered trailing weights (less aggressive).
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 08-29-2013, 02:28 AM   #642
M7H
M7H's Avatar
Pass you soon...
So, the answer should be no.
Serpent
M7H is offline   Reply With Quote
Old 08-29-2013, 02:59 PM   #643
djiewie's Avatar
yes is the right answer
and my choice always.
djiewie is offline   Reply With Quote
Old 08-29-2013, 03:34 PM   #644
M7H
M7H's Avatar
now I'm confused, and don't understand why I gave that answer.
But still, the left hole on the pin, is trailing, (motor rotates counter clockwise) so the right hole on the pin gives leading flyweights.....
Serpent
Old 08-29-2013, 08:08 PM   #645
Jazza's Avatar
Trader Rating: 16 (100%+)
Pass you soon...
Cheat & lil-bump have it correct With the engine spinning counter clockwise the end of the weight should be coming out as so it would lets say catch on something.
Lets say if you put your finger near the weight while it was spinning the end of the weight would hit your finger
If it's trailing and spinning counter clockwise the side of the weight would just brush past your finger if you get my drift. Sorry I don't have a pic to show.
M7H you're confusing yourself & everyone else
Capricorn Lab Co3....Black Edition Co2
Kickass Racing OS Racing Engines RB TXR Engines
Capricorn Racing Tyres....Highest Servo's....VP Racing Fuels
Supporter of Capricorn Australia....Walters Hobbies....JPM Racing
Jazza is offline   Reply With Quote
Tags
rc-world, serpent, serpent 747, toy fair
