RDLogics Mongoose
#976
Originally Posted by MartynD
Anyone running a spool in the rear?
Hate messing with gear oils....
The times to use spool is most likely when it's super-grip and using a GTP-style body
#977
Was there a lot higher tire wear running the spool as well?
I am a newb to foam tires, this past Saturday was my first real day of track time with the car (which is my first nitro). By the end of the day... likely 8-10 tanks if not more, I had ruined 2 pairs of front tires (hitting stuff) and the left rear was alot smaller than the right rear.
Lessons learned: Stop hitting stuff... switch the tires left to right between runs if you can..
Complete novice with nitro and foam tires, quite a few knowledgeable people helped me out, but in some cases they don't realize the small things us newbs need to know. Wasn't anyone else's fault but my own, but still a fairly costly practice day.
About hitting stuff... The ballcup that attaches to the steering rack popped off quite often (hitting stuff again)
I was thinking about converting to Xray style ball links, but before I do... by using stronger ball links do I risk damaging the steering servo? Are there better solutions?
#978
Regional Moderator
Hey guys, I took a look at the RDlogics site after I asked about finding spare parts, and had a question.
They have optional parts for the car listed there, but what if you need a kit replacement part? Do you just drop them an email with a part number from the manual to order that kind of stuff?
Or did I just miss the regular spare parts listing somewhere on the site?
#979
Yes Darkseid, you didn't search enough
This link takes you to spares (i hope)
MartynD. Yes, the rear tire wore alot more with the track conditions and setup i tried the solid axle.
#980
Originally Posted by Sparx
The Serpent seals i use looks like they're discontinued, i got them from my LHS who had some laying around.
The seals that's from the V-One RR is the exact same thoguh but i can't find any part numbers. I'll go see if i still have the bag around somewhere.
Thanks, i will wait for news about you ...
#981
Regional Moderator
I feel like the idiot at the supermarket who ask where to find something and the store clerk points and says 'you mean that thing behind you'!
Thanks Sparx
#982
#984
Hi guys,
Somebody knows if this Wheel Axle fit on the G4 front and rear hubs ? ... as i see the measures for the inner bearing (10x15) and outer one (6x13) are identical ... this is from Mugen MTX3 ... :
Thanks for any info ...
#985
I was replacing some of the pullies and I accidentally bought a 18 tooth brake pulley instead of a 19.Is this a problem or can I use it with the stock belt??
#986
That pulley will over drive your rear end a bit. This will cause the car to push. the only way to counter act this would be to run a slightly larger front tire.
Kinda think of it, you would probably be better off ordering the correct pulley unless you are ready to experiment.
#987
I believe putting an 18 tooth pulley in the rear will make the rear tires spin slower, not faster, you would need a slightly Smaller front tire than rear to compensate. The main reason you would want to get the proper pulley for the rear belt would be for belt tension, without a rear tensioner the belt will be pretty loose.
#988
#990
I will get the right one,but what would be the reason you would put in a smaller gear.I also noticed there is a 20 tooth gear as well.
