RDLogics Mongoose
#917
Originally Posted by rcrevolution
can you confrim that 3 allen screws will work 100%?
This is just a suggestion - try it and see for yourself. I once had a centex clutch that the weights came with allen screws.
#919
If you use the brass insert weights your clutch will not operate like it should in dry weather. I use the orange Kfactory spring (0,5 mm tension) and no inserts for good launch when high grip, if it's extremely high grip i usually go for the yellow spring (tension-nut flush).
In rain though, the Red spring and the inserts is an unbeatable clutch setup.
#921
I have a Few Questions About the Stock Clutch Set Up.
1 Is there anything I can do to Prevent my Clutch Weights From Hanging Up on the Flywheel? I Tried Taking the Rough Edge off the Flywheel. Helped but they are Still Hanging Up.
2 What, if anything do you Lubricate the Thrust Assembly With? I have been Using Associated Black Grease.
3 How Much Clutch Bell Play Dou you Want? I assembled per Instructions and there seems to be an Excessive amount of Play and the Instructions don't tell you the Proper Amount of Play.
4 Can the Excessive amount of Clutch Bell Play Be the Reason my Weights Keep Hanging up on the Flywheel?
5 Is it Normal for my Clutch Shoe to be Stuck to the Disk that Goes right Behind It? Does'nt seem to be Hurting anything other then when I need a New Shoe I will need to buy the Disk as Well.
Thanks in advance
Dax
Thanks in advance
Dax
#923
Regional Moderator
I've been looking at getting the RDLogics Mongoose...or Team Magic G4 or whatever the name for it is now. I'm looking to replace my R40 with it.
I had a few questions though.
-Is this car still having the steering rack problems that it was when it first came out? Something about not being smooth or getting hung up or something.
-Anybody come up with a way to protect that exposed reciever from impact?
-Where do you guys get parts from. I don't mind doing mail order, so thats not an issue. I just need to know that I can find G4 or Mongoose parts if/when I need them.
Thanks in advance for the answers.
-Darkseid
-Darkseid
#924
can anyone with AIM post their screen name up or pm me with it, I need some help getting started witht he mongoose and this forum sometimes takes forever to get a response on.
for the throttle linkage, where you need to use a flanged bearing, I used a regular one is that ok?
also are the front shocks suposed to be so stiff? and be stiffer then the rear shocks?
umm can I drill out a small hole in the clutch bell since it is messing the hole to adjust it externaly, I have very small drill bits and I can do it, if its ok.
#926
Lets see, my opinions on this questions :
I dont know, i still dont have the problem, half bottle of fuel already on my STS D3R engine and not a single problem with the centax clutch ....
I just use WD40 3-in-1 oil on my thrust bearings ... and not problem at all so far ... on my Yokomo GT4W2L i have been runing 2 years and half with the same thrust bearings without changing it with this method ... i dont know if its ok but at least is working for me ...
As soo as i finished my G4 EVO i saw that the play on the bell was excessive ... i left it with almost no play żjust feeling a little little "move" on the bell ... half bottle of fuel later not a single problem ...
Read answers to questions 1 and 3 i think ...
I dont undertood your question ...
hope this help ...
cya ...
hope this help ...
cya ...
#928
Dax
Dax
2. I use a Trinity light bearing oil for the thrust bearing.
4. I think so
5. ???, you should just need to buy a new shoe. The plate should be fine, unless it is wrapped or unusual wear.
Sparx is correct in that you can use or not use the brass weights/spring combo depending on your track. A lighter setting will enage latter for a high-traction track and a heavier setting will engage sooner for a slicker track. However, here in the States we usually don't run in the rain.
There is a great article in RCCarAction by Joel Johnson in the Aug 2004 edition. I set my centex clutches by his method, not what is in the manual.
my 2 cents.
#929
tabushi, do you have a little hole in your clutch bell to adjust the centex externaly? my clutch bell is missing it
