RDLogics Mongoose
#931
Originally Posted by Darkseid
I've been looking at getting the RDLogics Mongoose...or Team Magic G4 or whatever the name for it is now. I'm looking to replace my R40 with it.
I had a few questions though.
-Is this car still having the steering rack problems that it was when it first came out? Something about not being smooth or getting hung up or something.
-Anybody come up with a way to protect that exposed reciever from impact?
-Where do you guys get parts from. I don't mind doing mail order, so thats not an issue. I just need to know that I can find G4 or Mongoose parts if/when I need them.
Thanks in advance for the answers.
-Darkseid
-Darkseid
#932
Thanks for all the help! I can feel the Cars Potential but the Clutch has a Few bugs to Work out. Seems like I better get the Clutch bell Play to .1 .2mm Compared to the 1/16 Inch that I have Now. Hopefully This wll keep the Weights from Hanging up, Hoefully my weights were getting Slung out too Far. I will let you guys Know.
#933
Originally Posted by Tabushi
Just to confirm ... the short serpent springs fit OK ? ... on all 4 corners ?
thanks !
thanks !
#934
Originally Posted by rcrevolution
thats odd, I woner why mine doesnt have any...
would it be safe to drill two of my own with a small drill bit?
If you want to make the hole, that's fine but make sure you don't damage the part on the bell that touch the clutch shoe.
#935
for the throttle linkage, where you need to use a flanged bearing, I used a regular one is that ok?
also are the front shocks suposed to be so stiff? and be stiffer then the rear shocks?
The front shocks and the rears are the same, all four shocks should feel the same, then if you already put them into the car and the car feel stiffer in the front, it's ok.
#936
Darkseid
Rd Logics carries all the parts for the Mongoose. They also made a financial commitment to support the car. If your driving an R40 now you will love the responsivenes to the car. The current steering rack system in the car is okay. It requires some maintenance beyond a standard bell crank system, but it shouldn't hold you back from buying the car. The car really shines on high bite fast tracks. It's low center of gravity makes it feel like your driving a carpet car on asphault!
#938
Spring sets
RD Logics Sells a complete spring set for the car. They work great!! They may not be listed on there website but they carry them. I'm sure they will be less than a serpent complete set. I don't think serpent even sells them as a complete set.
#939
Well, here's a setup i thought you could check up
dunno shocklength though, the TRF's are at the same length as the standard dampers though.
*edit* Forgot the gearing, it's 20-24 and 52-47
#941
Does anyone here use the rear ball diff?Im not really a big fan of gear diffs.
#942
Fordman500... I used the rear ball diff last year because of the ease of tuning, overall performance was a tad bit down because of the extra weight... I know it says light weight, but it weighs more then the stock gear diff... If you don't like swapping out diff oils and diffs altogether, then give the ball diff a try... For me though, perfer the gear diff... Always have a couple on hand depending on track conditions...
RC_Alan
RC_Alan
#943
Thanks for the reply RC!!
Heres my problem.I filled the gear diff with 10,000 like you told me.I came back to it the next day and there was a puddle of diff oil on my table.I took it apart and everything seemed ok.The screws were tight and the gasket was intact.Im not sure whats going on.Like I said though Im not a big fan of the gear diffs anyway.As far as the weight goes,Im no where near the level of driving that a little more weight will make a difference.I just really dont want to mess around with swapping oils.
#944
From the Sedan Nats:
Photos can be seen in the gallery at http://www.jpsportspics.com/gallery/05sedan_nats
#945
Whose car is that?
