Kyosho v-one rrr
#6527
Originally Posted by ziggy12345
Where can I get the instructions for this part?
#6529
Originally Posted by Osiris 75
Hey guys, I found some 0 mm offset universals, but they are for the V1RR. Will they fit on the WCE???
#6531
Originally Posted by maskedrider
remember once saw a thread posting using a small spring inserting at the screw in between the brake pad in order to prevent the brake pad from jamming when release the brake... could someone refresh me
#6532
I just tried to fir the blue rear clamps with 3 holes in for the top camber links (forgotton the part number!) and there is not enough suspention movement after its fitted. I tried all arrangements of balls and spacers and still no luck. In the end I took it off and binned it! What a waste of money!
Anybody else had problems with it?
Cheers
Cheers
#6533
#6534
Hi,
Thought it's time to show some pics of my car. From the pics you can see I have modified the Top Deck for better access to the link on the servo horn. Notice the springs keeping the brake pads apart, also I have modiied the Skyline shock brace (two extra holes) so it will fit the new bulk head.
Picture 1 Picture 2 Picture 3 Picture 5
#6535
how did you cut the top deck?
#6536
Originally Posted by B4
Hi,
#6537
Just an observation, it doesn't look like you have sanded the edges of the top deck and sealed them with CA I could be wrong or maybe it's not adviseable with Nitro cars? Also I am glad that I looked thru my WC kit so I could mark the top deck for the clearance, as I was going thru the box I noticed that I have universal shafts front and rear supplied, I guess I should start building this thing before I order parts I don't need at least for now
#6539
#6540
Enjoy the ride
