Kyosho v-one rrr
#5807
Originally Posted by asw7576
How do you overcome stripping spur gear ( 2nd gear ) problem ?
#5808
Originally Posted by kewdawg
Yeah I need the part number for that and the blue aluminum camber link / diff holder / shock tower mount(sorry, don't remember the actual name). Can someone help us out?
Who makes the blade type sway bar... Kawahara? I would like to check that out as well.
#5809
Originally Posted by rmdhawaii
If you follow the messages in the MTX-4 thread today regarding gears, you'll notice that a few people recommended keeping the same teeth difference between the pinion gears and the spur gear to avoid stripping the gears - so if I drop the 16 to 15, I should drop the 21 to 20. Hmmmm... What do you guys think?
#5810
( Oops! )
#5811
Originally Posted by jag
I ran a 16/23, 61/55 combo without any problem at my last state race. My friend used 16/23, 61/56... again, no problem.
#5812
The "blue aluminum camber link / diff holder / shock tower mount" is actually called the SP Rear Shock Stay Set VZW207. I just installed mine on Sunday. It's pretty expensive.
#5813
Thanks, Jag. Yeah, I think it's made by Kawahara. No idea where to find it, though.
http://www.precisionrc.com/nv/car/pr...oduct_id=11861
when you do a normal search it comes up a goose eggs.
hey what are you all using to remove the pinions ?
I have the VZW040 wrench, works great for the second gear, but for the 1st gear does'nt for a flying #####
I have set of plyers that I have put shrink tube around the jaws, but looks a little cheesie.
#5814
rmdhawaii, that's the one. Shouldn't have edited your post. I was preoccupied and didn't post in time. oh, well drfritz got the english version.
drfritz, I've been using the plastic set that Hpi makes. It works pretty well if, you don't use a ton of thread lock on the pinions - and you have a strong grip. Here's a link:
http://www2.towerhobbies.com/cgi-bin...?&I=LXGBT2&P=0
#5815
KEWDAWG!
Okay guys, this is where you will find the Kawahara parts:
http://www.hikarisystem.net/kawahara...22V-one-RRR%22
If you want to find Japanese stuff, you gotta use the right search engine:
http://www.google.co.jp
#5816
Originally Posted by fritzD
is there another brand i can use for 3D weight for the centax clutch for the RRR? like mugen or something?
all three.
#5818
Originally Posted by joemugen
Robert,
I have two weeks of class left so I am starting to get my car ready for go racing. What is a good starting point for car set up for the rrr?
Thanks.
Thanks.
Hey joe that great to hear you coming back.....to be hones with you the stock setup works pretty well....if you want to see the setup I used at this years W-Nats just look back a few pages its on the rrr thread......see ya soon bud....
#5819
What will this mod do?
For one thing it lightens your weights......I was told to do this at W-nats by Bertin....And my clutch feels very nice since i have been doing it.....
#5820
Originally Posted by Jeff Cuffs
hey quick question do they make a wider rear hex so i can run the same off set rim and and still make width
