Kyosho v-one rrr
#2942
if you have an AM Radio, you will have glitches anytime you connect the glow driver or go to tune the engine with a screwdriver. If you have FM this does not happen with a good radio.
#2943
I currently have a KO Esprit II, but after chatting with Mark Green today, I will be ditching this for a complete Sanwa system (TX/RX).
He changed, not by choice, 3 years ago and has never looked back.
#2944
Originally Posted by NiMo
I have this happen to every car i've had, and i've always used FM radio.
#2945
sanwa suck.
Ko suck also.
and Hitec suck the most.
Ko suck also.
#2946
The experience here seems to be the opposite. Many people I know switched from M8 to Helios.
#2947
The KO is a better radio. One of the only that you can customize with your computer. Rings tones and Menu system. Plus the speed of the radio is better.
Sounds like you have a chassis problem. I have never had a problem with my helio, in anything nitro. But i make sure to take care of anything that might create a glitch too.
#2948
Guys, changed my Rx unit and the problem has gone - well, except when I touch a metal surface on the car with a metal object.
Thanks for the help, Mark.
#2949
Originally Posted by stefan
Yep,
leaving Friday morning, very early
Stefan
Stefan
Good luck at the race. Mark
#2950
good deal mark.
#2951
#2952
#2953
i saw the serpent 710 has the lower cg chassis. I think someone should make one for v1rrr. I will be interested to get one.
#2954
I would think that after 15 years of racing that I would know how to set up the radio gear in a car.
#2955
15 years and your still crap?!!
