Kyosho v-one rrr
#2776
Originally Posted by centax error!
jeffreylin, is that the reason why I am having the problem because I was running a narrow rear? and the overdrive has nothing to do with it. I will try putting 2 mm shims and thanks for the reply
#2777
Originally Posted by jeffreylin
I think you should do both. The overdrive certainly has an effect since you are running rubber tires with the same size front and rear.
#2778
Originally Posted by joemugen
since he is running the same size tires in the front and the rear with the 23t pully, he has "rear overdrive"--- which i think would definitely cause the rear to come around out of turns.... that's my 2 cents... jeffreylin, let us know if that makes sense.
With a 23T front it would give overdrive to the front, and with a fixed drive the rear would be like running with a handbrake on, which would cause the rear to break loose every time you came off the power.
#2779
Originally Posted by NiMo
I think it's the other way around.
#2780
Originally Posted by TRAJ
The 3racing brake leaver was screwed down too tight all the rebuilding for something so simple
#2781
Hey NiMo I noticed that you have a Sirio Evo2--what happened to the JP? How would you compare the two? I have an Evo2 WCR and that is one of the fastest motor I ever had.
#2782
Yeah, NiMo should know better. I've only ran foam but NiMo has been running rubber tires for a long time.
The JP was the best motor I've ever had in terms of performance and reliability, it was only just starting to go off tune after 10 months of running almost every weekend, I got the Sirio as it was cheaper ( a web site listed it at the wrong price ) but if it were choice then a JP would be first.
#2783
#2784
jeffrey,
i am thinking of getting a 1/8th scale. what do you think of the mrx-4?
#2785
Originally Posted by wad
Hey Jeffrey, what motor supposed to be faster from what you know, the EVO2 WCR or the EVO3??
However, that WCR is so fast I seriously doubt the Evo3 can be faster. My JP full option is as fast as everyone else's motor but my WCR was faster than everybody else!
#2786
jeffrey,
2: it's not a Kyosho
and finally
3: it's not a Kyosho
#2787
jeffrey,
However, I will say that all the people I've talked to love the Evolva. I know a few who have had both and they all seem to prefer the Evolva over the MRX4.
#2788
I don't know. The folks at Sirio say that Evo3 is superior to Evo2 WCR in every way. I got an Evo3 but I have yet to run it (will break it in tomorrow). Also the Evo3 is a 5 port so not exactly a fair comparison.
#2789
EVO3 is 5 ports?? Oops, my friend Fernando just got one, I will tell him to send the motor back and get a 3 ports. Is the WCR hard to find??
The only place I know that you can still find a WCR is Japan, but the price is quite high (over $400 now).
