Kyosho v-one rrr
#1816
Brakes
Hey guys I just ran my rrr for the first time this weekend and I noticed the brakes went away really fast on this car. What have you done as far as upgrades to give this car more consistant braking. Thanks.
Tenderfoot
Tenderfoot
#1817
Re: Brakes
Tenderfoot
Tenderfoot
#1818
Re: Re: NEW HUDY SYSTEM
You have to look at the bottom of your camber/toe gauge and you will see a little hole. Put this hole over the top of the small posts on the tweak station and adjust from there. You have to measure it with the wheels off, the station has the offset built in.
to coincide with your current track width. because mines dont.
#1820
Re: Re: Re: Brakes
I do have an alm. brake lever but the brakes still fade after about 3-4 times used. Any other suggestions.
Tenderfoot
Tenderfoot
#1821
Re: Re: Re: NEW HUDY SYSTEM
Originally posted by GUINT1
yES I know that but ist the numbers suppose
Tenderfoot
#1822
Re: Re: Re: Re: Brakes
Originally posted by jeffreylin
Check your servo and linkage. Also check if your stock plastic brake holder has melted. Replace with the aluminum brake holder if that's the problem.
Tenderfoot
#1823
Re: Re: Re: Brakes
Tenderfoot
Tenderfoot
#1824
#1826
1st-17/60
2nd-23/55
2nd-23/55
#1828
Re: Racing4Evo - Jeffreylin
Originally posted by wad
Hi guys!!
Could you please help me with a good gears combo for rev??
Thanks!
Hi guys!!
Thanks!
Did you get a RRR?
#1829
Do you know what are the stock ones?
#1830
Re: Re: Racing4Evo - Jeffreylin
I use 16/60 and 22/55. I tried 23/55 but it was too tall for me.
Did you get a RRR?
Did you get a RRR?
I didn't get the car yet, I'm looking to do it.
But I heard something about that they discontinue the car
Is that right??
