Kyosho v-one rrr
#1696
Super Moderator
Re: Re: Front Diff Problem
Originally posted by SpeedsterRRR
Maybe you should have your friend Fotis temporarily rebuild and reinforce the damaged part and stop bothering the people here about how to convert the one-way to a solid... since it is an irreversible conversion.....
Grinder did this to his one-way to make it into a solid a few post ago, and i beleive that it is reversible by removing the set screw.
#1697
Super Moderator
Originally posted by dmastroy
Last sunday, I destroyed the plastic part that makes the front diff a solid one. I ordered it but I haven't reveive it yet. In 5 days we have the first race for this year's championship.
What can I do? Is there a way to convert the one way diff to solid with out ruining it? (our track REQUIRES a solid front diff!!!)
If there is not any other way, how should I convert it to solid for sure?
Thanx for your imediate replies!!!
P.S. Gia sou Foti!!!
look at the above picture
#1698
RRR
Other than Tower Hobbies were can I get spur and pinion for RRR in the U.S by Friday?
#1699
Re: RRR
#1700
Where can I find setups for the RRR WC? I've looked att kyosho.com, but haven't found any.
thanks,
Arvid Stenberg
thanks,
Arvid Stenberg
#1701
Re: Re: Re: Front Diff Problem
Originally posted by Marcos.J
try this
try this
You may however try to remove the bearings, find suitable collars for the diff joints and so on.... but all this is too much trouble for a temporary fix.... Lets hope that the part comes in time... or that the alternative of fixing the striped plastic part with Boro 2 compound hard epoxy putty may last for one race....
#1702
Super Moderator
Re: Re: Re: Re: Front Diff Problem
Well, the one-way diff has 2 one-way bearings, which are irreversibly destroyed after you drill them...
#1703
East Parts
I noticed that RC-Mushroom have a range of East parts for the RRR. Has any tried these? What`s the quality like?
http://rc-mushroom.com/index.php?cPa...sort=1a&page=4
Cheers
Cheers
#1705
shoegoo will work, i have done it with a mugen diff,
after you fill diff leave one screw out so air will get to it and it will be hard as a rock the next day !!!!
#1706
Re: East Parts
Cheers
Cheers
#1708
Really? For how many laps did it work?
#1709
Best Engine
Hi to all,
Im planning to get a new Novarossi engine, can you advise me if you know some engine which is better than nova.
Thanks in advance.
Thanks in advance.
