New 1/8 on-road "XR8"
#948
Tried out some new settings on my XR8 and it became a much easier car to drive. I can drive it more agressively into corners.
front upper and lower arms raised thus moving roll center/cg up(is that right? I always mix this up) yellow springs ,flat front roll bars,40wt shock oil, almost neutral caster,-1 droop, 2'camber 1' toe
rear grey spring on 40wt,flat roll bar, 8 droop, 3'camber, 2.5'toe in.stock rear camber link angle(one alu washer)
track, bumpy tech infield, about 120' bend on straight, traction so so. 37 shore front and rear.
I hate settings sheet hence I leave it in here
#952
question on xr8 cars
Does anyone know where to get parts for xr80 or xr8's cars ??? if so drop me a line please( [email protected])<img src="cla........ ...Thanks!
#953
#954
BRC358 YGPM.
#956
Picco basic or Novarossi Basic engines.
#957
so if i have the kit and engine what else do i need to get it running
and will this engine work with the xr8 http://www.ebay.com.au/itm/Brand-New...item588e7bf609
#958
#959
will this be fine http://www.ebay.com.au/itm/Picco-P3-...&_qi=RTM839189
do a search on road engine
