Mugen Mtx4 clutch bolt ->
Hi the bolt on my clutch of my Mugen MTX4 (Allen head) has rounded. Could anyone advis me how to remove it.
Please also could you tell me the dimensions of it. The engine is a 1 season Ols navarossi .12 (1/10) cheers.
Cheers for suggestions, I will try first the hex that is slightly larger and hit it so it makes the edges flat again. If it dosent work (or if I can't do it)
then I will try the 'creating a flat head screw' I initially didn't want to harm the countersink, but I will getting an engine rebuild shortly so will have everything replaced.
cheers
Do you know what the dimensions are ? Or what other bolt would fit? Cheers again.- James.
cheersDo you know what the dimensions are ? Or what other bolt would fit? Cheers again.- James.
