Old 01-06-2011, 04:16 PM   #16
Geezatec's Avatar
The small wave springs I have found are very soft, they just give enough tension to push the clutchbell up and does keep the balls of the thrustbearing perfectly in the groove of the discs. The problem with to much play is when the clutch engages the balls of the bearing have to find the groove, at that moment a lot of forces are on the ring holding the balls and then after a few times the balls come loose...
I have these springs on all my clutches.
Another trick I have used for years is use a brass 10x5mm washer between the 2 steel discs, works perfectly and does not need any maintenance. You can find these brass rings at any hardware store at the screws section beside the steel screws and washers.
Hated those spring washers. Clutch react too soft. I rather have it react aggressively.
wingracer & HLLIB Been useing my endplay adjustment way before centax was release.. Before Serpent and Mugen even existed, when it was really a hobby of Pan cars Not the Pan cars you guys are thinling about.
Geezatec is offline   Reply With Quote
Old 01-06-2011, 04:25 PM   #17
Roelof's Avatar
Send a message via ICQ to Roelof
Huh?????
My experience with these wave springs is that it does make the clutch more agressive because it does keep the gap at its maximum and so the engage point to the maximum.
I think we are talking about diffent springs?
I have been experimenting with disc springs as a clutch spring, that is a different story I have not finished yet but looks promising with only the right material discs. Mayby you are confused with that?
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 01-06-2011, 05:13 PM   #18
Geezatec's Avatar
Huh?????
My experience with the Spring washer, Centex clutch uses centifugal force on applying pressue on clutch disc. Setting endplay to minimum w/o spring washer made it more aggessive, to my driving style. Early centex had had small shims when assembling the thrust bearing. My adjusment come with shim at the engine bearind & collet. Not useing the spring washer or small shims w/thrust bearing.
Do what you're confortable with. Like I said been useing my adjustment for years. Everybody does things that they're confortable with.
thrust bearing LiL_JaSoN Nitro On-Road 27 08-09-2010 01:47 AM
Thrust bearing cage? Loveless Nitro On-Road 26 06-22-2008 12:05 AM
Ball-less Thrust Bearing lil-bump Nitro On-Road 16 10-23-2007 11:49 PM
Thrust Bearing Question Please TRFTIM Nitro On-Road 26 05-25-2006 07:56 PM
NEW 3x8 Thrust Bearing Assy. 7.95 shipped dgullickson R/C Items: For Sale/Trade 43 04-07-2005 10:02 AM
