Capricorn LAB C801 1/8 scale
#871
Personally I recommend anyone to use Silicon grease to lube the one-way bearing. Basically the same stuff used to build a ball differential. Stuff from MR33 or Hudy works really well.
With the silicon grease the one-way bearing plus axle last at least an entire season.
#872
Dear All,
Has anyone tried the Capricorn conical washer (cap-417ss)?
What's your take on these vs conventional clutch springs? Read up on belleville washer but not much info with regards to RC application.
Many thanks in advance.
#873
On the new one-way the bearing housing has been updated to reduce flexture under load.
So if the one way is still fine i can use it and replace it later on?
Or will it damage my new shaft?
#874
I use ordinary Dexron/Mercon transmission fluid, a lubricant designed to work with sprag type bearings and clutches. Got away from using any kind of grease on a sprag bearing a long time ago as it tends to gum up roller engagement and attracted more dirt and tire dust.
#875
hello,
can someone please give a setup for ft myers?
thank you
thank you
#876
What's different between TYPE A and TYPE B?
What would the rear upper roll center change? (0,1.5,2.0)
#877
For the rear roll center. The higher up you put the pins on the lower arms the less traction you are going to have on the rear end. This will give the car more steering all around, as the traction in the rear is less. This is different than the top roll center adjustment with the linkage, just so you know.
DJ Apolaro
#878
Hi guys,
I've now bought the carbon fiber parts for the posterior upper arm.
1-2-3 There are legumes like what can you recommend to start.
Or what effect the no. 2-3 from then on the driving behavior
Thanks Mike
Thanks Mike
#879
Just know this, the longer link give more stable feel with less reactive response.
The more angle the link has, the more off power stable and more mid corner and exit rotation
The flatter the link, the more off power steering (slide) and more traction once you get on power.
Hope this helps
DJ Apolaro
#880
Without using numbers I will explain how the links work and you can see what position you want to use.
Hope this helps
DJ Apolaro
Hope this helps
DJ Apolaro
I see the Collari Edition is available. I'm a beginner of 1/8 on-road,
which step should i pay extremely attention during the assembly?
Front flex and rear flex, which one is better?
Thanks.
Victor
#881
Okay Thanks .
#883
Hi guys,
Has anyone tested the new wishbone front top?
What is the advantage over the normal?
http://www.capricornrc.com/capricorn...d_product=2212
#884
The difference would be, if you run the car short, you can set the car with more caster. Also you can run the car narrower as well.
DJ Apolaro
DJ Apolaro
#885
Does Capricorn make new car or new update of the LAB C801 CE version before the World championship in October?
