Kyosho SuperTen FW-04
#136
Yes I got them very nice thank you.
#138
#139
The first Superten that came out was way back in 1985 and some guys call it the FW03 but that was never the name it was only a super class car with Tamiya and HPI. and they where the only one that made them, Kyosho just keeped going with it until 2001. Then came the FW05 1/10 scale.
Yes they did make an sg flywheel for the super10,.. there are at least 2. Part number 39523, and 39524 (listed for 2 speed). These flywheels along with mounts 39522 allowed you to run a big block 15. Not sure if those flywheels will work with the small block mounts as they were designed to be used with a prop washer.
#140
#141
I have been running Superten for Years i just did not want to get into it with
1smexyAP2, I showed the pic of the flywheel to prove it. OH well. I do not run the Superten anymore because they stop making parts
and Yes the first Superten was just called a Superten and it was a slugg with a .10 Engine and a airplane manifold.
#142
this is what I made with the SG Engine with the 2-speed flywheel
#143
This is my Superten with a centax clucth made by Ofna.
#145
1 made by wolfpackradicals in Blue and one made by Admiral from Cross in silver. So which one are you Talking about.
#146
these are made by wolfpack
#148
#149
these are Kyosho and the Engine is a .18tz so it is a big block for the superten
