Capricorn LAB-C01
#1081
Bradley70,
Here is the new part number for those steel front cvd shafts
cap16063s
DJ Apolaro
cap16063s
DJ Apolaro
#1082
removing front diff
hi all
what is the secret to getting the front diff out quick and easy?
at the moment i need to remove the front foam bumper, shocker tower, 2 screw that hold in the wire sway bar, sway bar, 2 long screws that hold in the front upper part of thebulkhead and then switch out the bulkhead and the top arm hinge pin
#1083
hi all
#1084
Peter Jovanovic wins Qld. State Titles
Update from Queensland State Titles:
1. Capricorn driver Peter Jovanovic
2. Mugen driver Phil Woodbury
3. Capricorn driver Chris Watchorn
#1086
Kindest regards,
Lars.
#1088
If you're referring to our setup have a look in the file attachment; it works fantastically for us. At the same time; I don't claim to be an expert in setups; and I'm sure that there are other setups that many drivers will like better, and that our setup could be improved to work better even for us.
Hinge pin positions are measured from the lowest possible position in the sheet; and please note the short wheel base, the car is significantly better with that even on fast flowing tracks. it's a simple adjustment that I think everyone should give one try.
Also check the awesome clip of another Capricorn car's traction roll in front of our car. The track is very bumpy, but our car handled the bumps well with fairly hard springs, and the two Capricorn cars use significantly different race setups. The clip is cut from a race clip by Harry Sinanian who creates the best ever RC race footage. http://www.youtube.com/watch?v=nHq3SWtIo_Y
Kindest regards,
Lars.
Kindest regards,
Lars.
#1089
HD of Chance Karlsson through the bumpy sweep
File size : 10.2 MiB
Duration : 5s 248ms
Overall bit rate : 16.4 Mbps
Mp4 Version - ( Will play if Quicktime loaded - Once you download it. )
http://www.beachmumsracing.org.au/wp...sson_sweep.mp4
Zip Archived Files - ( For download, extract and watch from local HDD )
http://www.beachmumsracing.org.au/wp...sson_sweep.zip
More...
http://www.beachmumsracing.org.au/wp...s_Watchorn.zip
http://www.beachmumsracing.org.au/wp...chorn_Roll.zip
http://www.beachmumsracing.org.au/wp..._Jovanovic.zip
And yes Lars asked for permission to use...
The whole edit..
http://www.youtube.com/user/therealb.../0/8wI2kL9-WbQ
Watch the LABs in the hands of Peter Jovanovic and Chris Watchorn..
What I found most impressive... Chris Watchorn 1/8th Capricorn doing wheelies at top speed thru the sweep!
Duration : 5s 248ms
More...
The whole edit..
#1090
Anyone know where I can order a red and yellow clutch shoes for my wc clutch here in the states?
#1091
Hey guys,
Good results for the Capricorn this past weekend at the Xray Challenge
http://www.redrc.net/2011/08/dj-apol...ge/#more-46433
#1094
hi to everybody, i just got a lab c01 but haven't received it yet, so i have a couple of questions about the car, just to get ready before it gets to my hands.
do you know if i can use the the nt1 rear antiroll bars on the c01?
what battery are you using with the car? lipo or life?
have you tried the dark red shoe? how does it works?
how about using the white shock springs for a low traction track? or can i use the nt1 ones with the lab? well do they work as they were the same?
and does any of you have tried the new clutch bell? can remember de material name
and if you have any advice for the car it will be appreciate it.
by the way i got the euro version
#1095
@ mc chofo:
Hi!
ALL of your questions will be answered in the last 73 pages!!!
READ THEM!!!
Regards,
Black
Hi!
READ THEM!!!
Regards,
Black
