Kyosho V-ONE RRR Shimo Edtion
#61
Had a good test of the car for the first time this weekend at the RCX challenge. My car was absolutely great. Most competitive I have ever been. There was still a something to improve as I could lose the rear of the car on corner exit if I didn't roll the throttle, but even with that small issue, the car was simply awesome.
I'm glad to see Kyosho at the top, it was sad to see that wheel getting lose.
Anyways, good job.
#63
very nice car
#65
Congrats Scott, sounds like you did a fantastic job! So, what's your opinion - Shimo version makes you shine obviously - what's you opinion about the car compared to previous versions you've had ? Thanks
#67
OK, thanks Scott.
#68
brake question
Hi friends which brakes you would suggest for kyosho rrr series?
Kfactory G4/V1RRR Real Racing Brake Pads (For Most Kyosho Cars)
Kyosho V1RRR EVO/2 Acre Brake Pad
Kyosho V1RRR EVO/2 APP Brake Pad
and... U think the new brake Shimo disk is better than the old one? It's lighter, sure, but the pads have minor mass to apply force isnt'it? THANKS!
Sorry for my english i'm ITALIAN ...
Novarossi RULEZZ !
Novarossi RULEZZ !
#70
well i have a vone i just want some advice on a battery for my starter box. i used a gellcell to start my vone now i want to change to lipo. what would you recommend an 3s lipo? how many mAh battery i want it to last me a day at the track with out having to worrying about recharging it or blowing up.
#71
Novarossi RULEZZ !
Novarossi RULEZZ !
#72
#73
either 2x 2s or a 4s (lifepo4 is an even BETTER fit because it doesn't puff when over discharged) will be a better fit in your box.
Couple things to keep in mind when buying starter box lipo's 15c is too low, you will puff your pack quickly, especially with 1/8 scale, 25c or better 40c is overkill and a waste of money.
2000mah should last you a full race day and some, I've run 2 days plus on 2500mah.
Use deans or another high current connector, those starter box motors can draw high amps when starting a tight motor.
From personal experience Hyperion, Protek, Tenergy, and Turnigy all make decent quality low cost 4s 25c packs.
#75
thanks guys. i think im going to have to go with 2 x 2s. my charger doesnt accept 4s lipos
