Trinity Reflex NT - Any good? >
Old 03-13-2004, 07:53 PM
  #16
Bounty Hunter's Avatar
Default Re: Re: Re: Trinity Reflex NT - Any good?
Originally posted by drfritz
mmmmmmmmmmmmmmm what about the rest of us?
Ok ok fine....
Its the 24 tooth rollout conversion for the Kyosho V One RR. It will work on an Evolution and Trinity Reflex as well. What it essentially does is adds 5 teeth to your total rollout. At a 16/20 44/48 gearing I am like 5.6:1 in 1st gear and 4.2:1 in second. The converison replaces the teo 19 tooth 2 speed shaft gears with much larger ones. The only drawback is that you have to use an engine with enough low end to push the car in the infield. I myself have been running an RB V15 with a lola body running Outlaw. The engine is still stock and flies with that ratio. Plus it allows you to run tiny tires and still have plenty of gear left.
Bounty Hunter is offline
Old 03-14-2004, 05:22 PM
  #17
popsracer's Avatar
Default Re: Re: Trinity Reflex NT - Any good?
Of course there enough gearing available Steve. I thought I showed you my Outlaw car. Its got some massive gearing on it. Next time I see you at the track I will make sure that I show you.
Bounty Hunter;
Yes, I even went out and bought the pulley set for myself, but decided that it may be TOO tall for my needs. (still NIB if you're interested)
I have a 23T pinion coming and with the R40 spurs too, I should be fine from now on.
Guys;
Today I found out that the 1M Spur Gears from an HPI R40 are a direct fit on the Reflex (I tested this myself). The R40 has 43T and 42T second gear spurs availible which will help on the larger tracks and cut down tires.
popsracer is offline
Old 03-14-2004, 06:28 PM
  #18
InitialD's Avatar
Default Re: Re: Re: Re: Trinity Reflex NT - Any good?
I believe with the 24T conversion, you're at 6.0 on the first gearing and 4.4 on the 2nd with the mentioned spurs and pinions.
InitialD is offline
Old 03-14-2004, 10:20 PM
  #19
wild gopher's Avatar
Trader Rating: 39 (100%+)
After all these replies I went with the MTX-3 and so far think its a great car.
wild gopher is offline
Old 03-18-2004, 12:32 AM
  #20
Originally posted by popsracer
Bounty Hunter;
Guys;
Now you do know that Kyosho makes a 15T first gear and a 19T second. As far as being too tall.... Well like I said the only requirement is to have an engine with enough low end to carry the infield. But if you are selling your gears, I am always looking for spares.
Old 03-18-2004, 02:23 PM
  #21
drfritz's Avatar
The smallest you can go on the reflex is a 16, yokomo gt4 pinoins work for the first gear.
drfritz is offline
Old 03-18-2004, 07:24 PM
  #22
popsracer's Avatar
Yea, like that RB-V15
Maybe see you this Saturday.
Old 03-18-2004, 10:25 PM
  #23
Default Re: Re: Re: Re: Re: Trinity Reflex NT - Any good?
Well with a little timing and crankshaft work, we can get that V12 of yours to scream like it too!!!!
Old 03-18-2004, 10:51 PM
  #24
who does all your engine work?
Old 03-19-2004, 07:10 PM
  #25
popsracer's Avatar
Default Re: Re: Re: Re: Re: Re: Trinity Reflex NT - Any good?
Definately could use a little more power.
I did get my 43T spurs today, so I'll have them on the Car for tomorrow evening.
See you at the Track!!
