Trinity Reflex NT - Any good?
how does this car hold up against Mugens and Serpents? Just curious because someone offered a trade for one, but I dont know much about them
I had one before my G4. The car works pretty well but is a generation behind the mtx3, 710 and G4.
For Rookie or sportsman type racing, It would work great. In very competitive racing, it may hinder you. |
Had one to, worked great, built like a tank, but was getting alittle old so I got the evo conversion for it,waiting for the season to get started to see what the new girl will do.
The reflexx will work fine for you if you get it,it can still hang with the newer cars at he local tracks. |
wild gopher;
Since it looks like you would be racing it at Revelation raceway, I would recommend one of the newer generation of Cars (G4, V1-EVO, MTX-3, etc). I own 3 (built) Reflexes and on a high speed, high grip track like Revelation, traction rolling has been hard to eliminate. The newest generation of Cars have suspension refinements that allow them to work better on this kind of track. |
thanks for the input, and yes revelation will be my home track (which it already is for offroad) so Ive narrowed it down to either the MTX-3, TC3, or HPI R40, most likely the mugen
I'll throw my hat into the ring here to with the "I had one..." line.
I ran mine all last year against MTX-3s and NTC3s. I felt that I wasn't at any real disadvantage simply because of my cars design. I finished consistently in the top 2 of the A-Main despite using only a mild powerplant(O.S. .12TR) and really was pleased with the car. The best part about it was how well it responded to small changes. I've moved on to the HPI R40 now. Not because the Reflex wasn't good enough anymore, just because, well take a look at my signature...!:sweat: :cool: |
Originally posted by drfritz Had one to, worked great, built like a tank, but was getting alittle old so I got the evo conversion for it,waiting for the season to get started to see what the new girl will do. The reflexx will work fine for you if you get it,it can still hang with the newer cars at he local tracks. Hi whats the evo conversion? |
Originally posted by fenix Hi whats the evo conversion? |
I also own a Reflex. It is a very good car and is capable of winning still. I recently switched to Mugen and like the Mugen better but I yesterday I was running against a Reflex and we were even steven all the way. I thought the other guy had a Mugen until we talked. When set up right, it can hang with the newer generation cars.
Originally posted by drfritz the evo is the evolution cconversion from kyosho the car is all new from the egine foward, oonly thing you use is the rear end and the drive train. go to tower hobbies and type in v one rr in the search to see it. Is this? v one rr |
tank number kyosho # 92050 belt- brace kyosho# vzw002 the front shock tower will not work with the trinty upper mounts, you can make your own or buy one from www.precisionrc.com if you are runing a front gear diff your going to need these kyosho # VZ118 The conversion comes with .8 gears but they will not work with the stock two speed, if you want to run them your going to have to go kyosho and buy there two speed asy.... |
Guys;
Actually, my ONLY major complaint about the Reflex is: On a high speed track that is sprayed with VHT, grip can become so good that traction rolling is a problem. Cut down tires help, but then there isn't any Gearing availible that is tall enough to bring the rollout back up. Other than that, the Car has been good to me. |
Re: Trinity Reflex NT - Any good?
Originally posted by popsracer Guys; Actually, my ONLY major complaint about the Reflex is: On a high speed track that is sprayed with VHT, grip can become so good that traction rolling is a problem. Cut down tires help, but then there isn't any Gearing availible that is tall enough to bring the rollout back up. Other than that, the Car has been good to me. |
Re: Re: Trinity Reflex NT - Any good?
Originally posted by Bounty Hunter Of course there enough gearing available Steve. I thought I showed you my Outlaw car. Its got some massive gearing on it. Next time I see you at the track I will make sure that I show you. mmmmmmmmmmmmmmm what about the rest of us? :cry: |
