Shepherd V8 '09 >
Shepherd V8 '09
Shepherd V8 '09
Old 01-25-2010, 07:00 AM
  #121
IgorR's Avatar
Originally Posted by coupe
hey guys,
i am back to the board and can answer some questions.
The 2010 kit is available from now on, it includes the new
pulleys and pulley adapter and the longer front belt.
Nothing else will be changed.
The new, shorter side belt should be available within the next weeks,
but for sure before the season in most of the countries will start.
The new chassis will not be a part of the 2010 kit, its not a need to have part, you can see it like a setup option part.
regards
Alex
Thanks for the Information,
Just to make sure that I'm going to buy a 2010 kit. Could you give me the ref number?
Does the car come with the upright?
IgorR is offline
Old 01-25-2010, 08:02 AM
  #122
Hey,
well the 2010 kit will have the same item number like the "old" one.
You will have to ask your dealer if he already have the new batch.
The new kits are shipped since last week.
You also should check if the distributor already have new ones.
Just ask them.
What do you mean with the uprights ???
Alex
coupe is offline
Old 01-25-2010, 08:59 AM
  #123
IgorR's Avatar
Hey,
Just ask them.
Alex
I mean the front and rear Exentric upright.
Thanks again I'll check with my dealers about the car. I hope they'll have it.
IgorR is offline
Old 01-25-2010, 10:34 PM
  #124
OK,
this uprights are in the kit for a long time now. You only need to buy the aluminium excentric parts and the ballbearings.
coupe is offline
Old 02-03-2010, 12:05 AM
  #125
anyone knows internal ratio for Velox V8 ?
thanks..
vegadeoo is offline
Old 02-03-2010, 12:09 AM
  #126
sorry for double post..
vegadeoo is offline
Old 02-03-2010, 05:21 AM
  #127
Suspended
thanks..
You can download a tool from Snake... and fill in your own numbers
PMSorber is offline
Old 02-04-2010, 09:23 AM
  #128
wmay11's Avatar
Giving Velox a bash this season, what is a good starting point? Clutch the same Mugens?
Thank you.
wmay11 is offline
Old 02-04-2010, 12:10 PM
  #129
speedracer1bp's Avatar
Trader Rating: 20 (100%+)
Thank you.
Mugen clutch and Velox are very similar. You should have no problems, however you can go to CEFX.com and download Josh's set-ups for the Shepherd and he has good settings for the clutch in there.
Hope this helps!
speedracer1bp is offline
Old 02-05-2010, 09:11 AM
  #130
wmay11's Avatar
I recieved my Velox today...............oh man this car is stunning! What are the best performance hop ups to get....eccentrics??? Not sure, will still keep my X as a backup. I cant believe the braking system on this chassis!!!!!!!!!!!
wmay11 is offline
Old 02-05-2010, 10:42 AM
  #131
wingracer's Avatar
Trader Rating: 24 (100%+)
Haha, check out the gold plated Velox on RedRC.
http://www.redrc.net/2010/02/toy-fai...rd/#more-27517
wingracer is online now
Old 02-05-2010, 12:17 PM
  #132
DS Motorsport's Avatar
Yes, I heard 50 cent it the newest addition to the Shepherd team drivers.
DS Motorsport is offline
Old 02-21-2010, 03:44 PM
  #133
Default Rear (low-friction) belt tension
Hi everyone,
Could I have some opinions on rear belt tension? I normally run the optional/low-friction belts in the tightest ("C") setting, but do many people run the belts in the normal, or even loosest settings? How is the life of the belt at these settings?
- As much as I'd like to reduce the belt tension a bit, I'm afraid of stripping the belt during a race.
Thanks,
Kronos.
Kronos is offline
Old 02-22-2010, 12:36 AM
  #134
Suspended
Originally Posted by Kronos
Hi everyone,
Thanks,
Kronos.
Kronos, we always run the LF belts during competition, normal belts during training. We place the belt tentioner on normal, not on tight. The belt wear depends a lot on the track (dirt and surface). You could also grind the top of a normal belt to extend its life a bit and have an almost similar LF-effect.
PMSorber is offline
Old 02-22-2010, 07:54 AM
  #135
Pooh2's Avatar
I ran my belts ont the car the whole time at the winternats. Practice 6 quals and engine break in. I didn't have to change them for the main but did anyway. Belts seem to last a long time if you ask me. They where the soft belts so...
Pooh2 is offline
